No, it's a one-way check valve, not a bypass. What should happen, is when the city water is connected, the pressure from the city water closes the valve, which stops water from reaching the pump. Sometimes a bit of dirt can get in there, preventing the valve from fully closing. Disconnect from city water, run the pump, and open a tap so the water actually flows, will sometimes move that bit of dirt and let the valve then close. If that doesn't work, then the valve has failed. Rare on a new rig like yours, but it does happen. Easy enough to replace, but if the 'run the pump' option doesn't work, I'd just have the dealer deal with it under warranty.
