Old 10-10-2020, 09:27 PM   #1
Fresh water tank not filling completey
Campground has lost water pressure. Having fill fresh water tank. Have 2020 8326bh. Should hold 60 gal. Can only get about seven gal in it. Keep refilling but overflows after just refilling some. Sensor shows only two out of eight bars when starts to overflow. Tested fill amount by filling and flushing toilet. Thanks for any help. Vent does not appear to be stopped up.
wicksmith is offline   Reply With Quote
Old 10-10-2020, 09:53 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
Are you sure you are filling into the fresh water tank and not the city water? If I understand correctly, the fresh water overflow tank is where the water discharges when it stops filling?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2011 2500HD Silverado
1992 Goldwing Aspencade
oxcamper is online now   Reply With Quote
Old 10-10-2020, 10:09 PM   #3
Thank you for the quick reply. Filing the large hole with a screw off cap in the back of this rig. Says fresh water fill. Appreciate any help.
2019 F350,, propride hitch
2020 Rockwood 8326BH
Old 10-10-2020, 10:12 PM   #4
Other peculiar part is that the tube for the fill is overflowing, it is not coming out the breather hole.
Old 10-10-2020, 10:26 PM   #5
NMWildcat's Avatar
Have you tried turning down the pressure at the spigot so the flow into the fill port is less? I have to fill mine at about half flow or it will puke out the fill port.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-10-2020, 11:04 PM   #6
Try again, sliding a long hose as far into the filler neck as you can, and filling slowly.
I had the same problem. I tested the tank capacity using a flowmeter but didn't get past 25 gallons. I thought I was going to have to pull the underlayer and diagnose a problem with the vent or overflow lines.
Before doing that I bought a long piece of vinyl tubing and added a hose connection to make a filler hose. I was able to get it about 4 feet into the filler neck. That enemies me to put 60 gallons in the tank.
I surmise that the air vent was plugged the first time I tried and that the water flowing down the fill tube prevented air from venting back out that way. By extending the filler hose farther in, air was able to vent during filling and didn't prevent filling completely.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 10-11-2020, 07:36 AM   #7
The trickle of water coming out of the hose is not of any pressure worth writing about. Good idea though.
Old 10-11-2020, 07:38 AM   #8
Did the air vent ever clear?
Old 10-11-2020, 07:57 AM   #9
jeff64's Avatar
Place e a piece of tubing over that vent adjacent to the fresh water fill opening and blow through it. If blocked by a slug of water, you'll know instantly. Once cleared you'll be able to fill the tank.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 10-11-2020, 10:01 AM   #10
NMWildcat's Avatar
Then it appears either your gravity fill port hose into the tank is kinked/blocked, and/or your vent hose.
Old 10-11-2020, 10:59 AM   #11
oxcamper's Avatar
2X
Old 10-11-2020, 11:13 AM   #12
KyDan's Avatar
Are you trying to fill with a piece of cut off hose stuck a couple feet into the fill port or just holding your garden hose against the fill port opening?? Big difference!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 10-11-2020, 03:32 PM   #13
Had the same problem. Took a good white hose and cut it off at about 14. Made azure the female end is attached. Slide it down into the fill hole. The female end keeps it from faking all the way down the hose. I pull it out a couple inches and screw my hose onto it. It fills great. When done, simply unscrew the hose, slide the short hose down into the hole and put the cap on. The length of hose you slide down into the fill hole goes past the where it usually needs to activate the breather. Hope that makes sense. Its made filling ours so simple and keeps your short filler hose clean and hidden away.
GmaB is offline   Reply With Quote
Old 10-11-2020, 08:29 PM   #14
Thank you all so much. I will try all the above tomorrow. You guys are great. Thanks.
Old 10-11-2020, 08:41 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
Camping World (and other places) sell a 3' filler hose with a hose connector and a shut off valve. It makes filling up the fresh water tank a breeze.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 10-11-2020, 11:36 PM   #16
This is what I use. Combined with a flow totalizer I set a timer and walk away.Click image for larger version
hinkle_e is offline   Reply With Quote
Old 10-12-2020, 07:56 AM   #17
KyDan's Avatar
I use a cut off washing machine hose. (They have female fittings on both ends.) You can cut one in half and have a hose for filling your tank and another for filling buckets or watering cans around the house. You can add a shut off valve from the garden dept of Wally world for a buck.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 10-12-2020, 09:07 AM   #18
I use the filler hose as others have suggested. I can run full blast for about half the fill, then it starts to gurgle and spit back out the fill hole. I cut the volume back and it still gurgles but quits spitting it back. Your vent is probably at least partially kinked. Try lowering the volume. May be a pain but it gets the job done. I wouldn't think it would be terribly difficult to get to the vent hose and be sure that it is open. Usually not a very big hose so that in itself could be the problem.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 10-12-2020, 09:33 AM   #19
Here is mine. I run it about half flow (never seen the need to 'Blast' water in the fresh tank) and know exactly how much I put in.
Days Camped: '18=51 '19=58 '20=110 '21=21
Old 10-25-2020, 08:17 PM   #20
This may not apply to your RV, but on my MiniLIte 2105 (2020) I discovered I simply cannot fill the fresh water tank when the RV is hooked up to the tow vehicle. With even the slighted nose-down angle, the water just runs back. So, if I have to fill it at the campground, I put the tongue jack down with the trailer hooked up and raise it until the rv is level. Then it fills completely. The fill hose has a long horizontal run, so the RV must be level or nose up.
-Al
Al
2020 Mini Lite 2205s
awagnon is offline   Reply With Quote
fresh water, tank, water, water tank
