07-03-2020, 05:45 PM
Fresh water tank over flowing
I have a 2013 Palomino Columbus and when I hook up water at the camp the fresh water tank fills up and over flows. Dealers want $145 an hour or more and won't give advice. Anyone else have this problem or a cure. Looked for a shut off but didn't see one.
07-03-2020, 06:31 PM
Try this
The check valve on your water pump is not seating properly, allowing city water to fill the fresh water tank. One thing to try:
1) Turn off city water at the source;
2) Turn on your water pump and open-and-close various faucets in your camper allowing the water pump to cycle on and off;
3) Turn off water pump, open a faucet and relieve water pressure;
4) Turn city water back on.
2020 F-250 XLT
2020 Salem Cruise Lite 241QBXL
KE8SDQ
07-03-2020, 06:40 PM
Just as confused as you
Originally Posted by Ryan-OH
Try this
x2
I will add it works better if after turning off city water then relieve the pressure before turning on your water pump. In either case you should let the water pump cycle 2 or 3 times before going back on city water. And never run your water pump while using city water.
Richard & Jill
07-03-2020, 07:05 PM
Thanks guys did just as you said and it looks like it took care of my problem. The water pump switch is next to the water heater switch so it probably got turned on by accident. Again thanks for the help.
07-03-2020, 08:58 PM
Well I guess I just can't win. Checked water tank and it's half full. Guess I'll pull the pump and check it out after the weekend and I get some more fishing and catching in. Thanks again for the advice I think it's on the right track.
07-03-2020, 09:12 PM
You can also add an inline check valve at the outlet of your fresh pump such as this:
https://www.amazon.com/Camco-23303-B.../dp/B000EDUTN6
but the problem is 100% definitely failure of the check valve built into the water pump.
07-04-2020, 12:41 PM
IndyDave
I had the same problem and it is the check valve in the water pump. Try recycling the pump a couple times and see it it stops. If that works then good, if not then you will have to replace the pump.
IndyDave
2013 Palomino Columbus RS320
2012 Dodge RAM 2500 Diesel
07-04-2020, 01:07 PM
Calcium or debris in the fresh water tank check valve. This is a good 'Red Flag' on why, when camping, the the 'city water' should be shut off when not at the camper. If the check valve or any of the water pipes have an issue, a lot of water damage could happen if not caught in time.
Brother Les
07-04-2020, 01:31 PM
This is a known issue with those pumps and there are loads of comments about it on this forum. It beats me why shureflo hasn't come up with a solution.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
07-04-2020, 03:44 PM
a spec of anything could possibly keep the check valve slightly open and cause a slight back flow leak. Pure, clean water is impossible to have as all water has some type of substance (ie. minerals) in it. The pump manufacturer can not control all of the environmental issues that may come along and be pulled into the pump.
Brother Les
07-04-2020, 08:57 PM
Ham Call N8SAC
I have added a valve in line to pump one TT I had. When on city water close valve . When on tank water open valve.
07-05-2020, 07:30 AM
water filling fresh water tank
Had the same problem. purchased an adjustable pressure regulator and set the pressure a little below 50lbs and it solved the problem. The check valves on these pumps are only rated for about 50 lbs and campgrounds have to run high pressure on their water lines to supply everyone.
2018 Rockwood 2606WS
2005 Ram 2500 Cummins
07-05-2020, 07:36 AM
PhD, Common Sense
Good point. We connect a generic pressure regulator. Does anyone know what pressure the manufacturer is typically setting these for?
BTW, if almost everyone is using some kind of water pressure regulator, and one person is not, does he get ALL of the excess pressure?
*pictures an RV exploding like a water balloon*
07-05-2020, 12:23 PM
Good points. My first thought when I read your reply was that this happened when the trailer was brand new so it must have been the pump manufacturer's fault. Then I remembered how much remaining saw dust and crap is produced during the build process, so I guess I can't really blame the pump maker. BTW, the dealer said the only fix was to replace the pump. It was under warranty, so there was no cost to me. Just annoyance. Now I know about adding another check valve,
DrLewie
Flemington, NJ
07-05-2020, 11:01 PM
Well I thank all who have replied and I think I'm going with the shut off valve. Sounds like the best bet for me. My pump works great but like my kids won't shut off (up)
