Old 05-12-2017, 11:05 PM   #1
Fresh water tank problem
Have a 8289ws
When hooked to city water the fresh water tank fills up. Have to turn off city water and use fresh water tank. Pump works great. What's causing the water to bleed into the fresh water tank?
RILEY6309 is offline   Reply With Quote
Old 05-12-2017, 11:10 PM   #2
There is a check valve in the pump. If that valve seal is bad or stuck open, it will allow the city water to bleed through into the fresh tank.
BooHyde is offline   Reply With Quote
Old 05-12-2017, 11:26 PM   #3
Can this be repaired. If so where do you get parts?
Old 05-16-2017, 06:38 AM   #4
Head Rambler
It can be repaired. They make repair kits for them, but it may be just a piece of trash holding the check valve open, and all it may need is a good cleaning out.
Find the model number of your pump and you can lookup the manual for it. That will tell you the disassembly procedure for it.
Gotta go campin!
Old 05-16-2017, 07:01 AM   #5
Thank. Plan on removing it today and checking it out.
fresh water, tank, water, water tank
