Originally Posted by camper_Lucy
Maybe I am all wet here but...
lets back up for a moment, the pump does have a backflow preventer as stated (to prevent city water hookup from flowing into FW tank) but OP stated he was filling FW tank so the backflow should not come into play as he is putting water into the tank not charging the system with a city water hookup.
1. filling the FW tank should not pressurize the system (that is a function of the pump), only way I see pressure being created in this fill process is if the tank overflow is blocked up, otherwise any pressure and eventually water would flow out of it.
Clarification...As I was filling the close-to-empty FW tank, water was clearly leaking out of the strainer cap. Tightened the cap, leak stopped. I continued to fill FW tank, with no problem.
So---Water must've have been pushing into the strainer cap side of WP as the first response stated?
You are right, the backflow preventer should not have been in play, right?
Once the FW tank was filled, water started to come out of the overflow pipes underneath the RV - as I would expect. So I don't think there is a blockage or anything going on with that. Afterwards we turned on the water pump and opened the faucets, seemed to be no problem there, either. No leaks, or anything out of the ordinary...
