03-01-2022, 07:56 AM
#21
sounds like someone bought a very cheap house to swell like a sausage all the years of have a hose laying in the sun hooked to a stock water tank with out a device hooked to limit pressure I have never seen it and i am 70
03-01-2022, 08:07 AM
#22
Originally Posted by 5picker
X2
I've seen non-protected water hoses swell and burst from the hose getting soft in summer sun.
It would be foolish to have a pressure regulator anywhere but the pedestal/supply source.
X3
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
03-01-2022, 08:21 AM
#23
So who protects the black flush hose and system with a pressure regulator??!
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
03-01-2022, 08:29 AM
#24
Trailer Park Supervisor
Not me. Even if I hook it up because I will be there a couple weeks, it stays off until you need it. And when you turn it on, it's kind of on an open system not prone to high pressure leaks.
Yes, I drink the water!
03-01-2022, 08:49 AM
#25
I do but only because of how I connect my flush hose. (when at a full hook-up site)
My low point drains have 1/4 turn ball valve, garden hose fittings on them.
I connect my short flush hose to one of them and since my R/V is protected by the regulator at the pedestal, the flush hose is inadvertently as well.
But as Kris mentions, the flush is an open ended system where unless the nozzle/feed line is blocked, there really isn't much pressure, just flow.
If I flush at home where the R/V may not be connected to a water source, then no.
03-01-2022, 08:53 AM
#26
Nice idea with the low point drain!
2014 Ram 3500 DRW
03-01-2022, 08:59 AM
#27
I use them for a lot of things.
It gives me a nice location at the R/V to connect a garden hose (for vehicle washing, dog washing, R/V washing etc.) and has allowed me on several occasions when boondocking, to pump a few gallons of my water to someone elses R/V whom had run out.
03-01-2022, 09:06 AM
#28
Just curious what you use the male to female adaptor for. Is that what the brass thing is on cold line?
03-01-2022, 09:24 AM
#29
That's just a garden hose cap, to keep road dirt out. When I snapped the photo I had removed the one on the hot line for whatever reason.
Getting somewhat off topic (but related to water pressure) they also provide for a good spot to monitor water pressure in your R/V.
When the air pocket depletes in the water heater, thermal expansion can raise regulated pressures to levels most folks would not believe if they didn’t see it. I've seen pressures over 100 PSI.
03-01-2022, 09:38 AM
#30
How does one restore the air pocket in the water heater?
03-01-2022, 10:24 AM
#31
Do you really want an air pocket in your WH?
Retired Navy
2016 Flagstaff 26 FKWS
03-01-2022, 10:30 AM
#32
Turn off water supply, release pressure at a faucet, open T&P valve on water tank until no water runs out, restore supply pressure. (CAUTION if HOT!)
I find while full timing here in FL for the winter I need to restore mine about every 3 weeks or I start seeing thermal expansion pressures around 100 PSI. I can always tell when it needs done as the foot pedal is hard to (initially) press when trying to fill the toilet bowl.
03-01-2022, 10:31 AM
#33
Yep
03-01-2022, 10:56 AM
#34
Thanks. The longest I've ever camped was 2 weeks, not sure when the air pocket for thermal expansion 'goes away'
03-01-2022, 11:02 AM
#35
Suburban says yes (starting at 1:30):
03-01-2022, 11:10 AM
#36
When setting up I always check the water pressure at the spigot. Also, I check the 'static' pressure after the regulator to make sure the regulator is doing its job.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
#37
learned something new with regard to WH.
Retired Navy
03-01-2022, 11:14 AM
#38
Good refresher video.
03-01-2022, 11:17 AM
#39
watched the video good info I have a 2 gal expansion tank on my system so this should not be a problem for me. JMHO
Retired Navy
03-01-2022, 11:37 AM
#40
Do you add a pump inline to create pressure for washing when attaching a hose to the low point drain? Curious how you create enough water pressure in that line.
