Gray/Black tank leak
I'm new to emptying RV tanks so I am not sure what to make of this....
I emptied the RV twice this week for the first time. On both occasions when I took the cap of the empty port (empties both gray and black tanks) there was a small amount of water that immediately poured out. The black and gray valves are approx. 4 inches behind the cover and there was maybe 1/2 cup of water in between the valves and the cover.
Is this normal? Should there be zero water in there? Is a small amount of water to be expected? I guess I was expecting nothing to be there so I was surprised (but I did have gloves on, yah!!). Or do I have a valve leak I should concern myself with?
Thank you all for the input!!
TT: 2021 Forest River Wolf Pup 14CC
-Battleborn lifepo4, Victron charge controller, Victron battery monitor, 200 watts solar, Renogy 2kw inverter, WFCO lithium converter charger.
TV: 2021 GMC Acadia AT4
