09-04-2020, 09:46 AM
Gray Water Tank Size
We have a 2020 FR TT, Toyhauler are camp hosts at a park in Washington that does not have hookups.
Our gray tank seems extremely small. I’m very careful about short showers, wetting down, turning water off, soaping, rinsing, and use small tubs for washing dishes and drain dish water into toilet and still the tank fills almost everyday. We’re lucky if we get two showers before it has to be drained.
I’ve looked through paperwork to find size of tank but it’s not there. It’s not the sensor as it is really full as it backs up into shower when full.
Is this the norm? Is it possible to have a larger tank put in? We plan on working here again next summer so wanting to plan.
09-04-2020, 11:45 AM
According to PrimeTime's website, the Avenger 20RD is not a toyhauler. It's a regular TT.
Their website says you have a 42 gallon FW tank and 34 gallon gray tank.
Not sure why you just didn't check the website.
I'd say that 34 gallons is pretty good for that size trailer. I had a HTT about the same size and it only had a 25 gallon gray tank.
09-04-2020, 11:56 AM
Grey tank is 34 gallons
SPECIFICATIONS
Hitch Weight:600 lb.UVW4176 lb.CCC3424 lb.Exterior Length:24' 11"Exterior Height:10' 3"Exterior Width:96"Fresh Water:42.00 gal.Gray Water:34.00 gal.Black Water:34.00 gal.Awning Size:13'
Fonzie
09-04-2020, 02:17 PM
Different camper
Thanks Bijendan, this is in regards to a dif camper; our 26 foot 2020 FR Wildwood FXS 260RT toyhauler.
09-04-2020, 02:21 PM
Update with more camper info:
26 foot 2020 FR Wildwood FXS toyhauler.
CH & Sharon Romine
The Rambling Romine’s
Living an Uncharted Life
09-04-2020, 02:26 PM
So I did look it up and it say 28 gallons. Is it possible to replace it w a larger one?
CH & Sharon Romine
09-04-2020, 02:47 PM
That looks like 30 gallons of gray. For two of us, our 52 gallon gray lasts about 2 1/2 days with two showers a day and dish washing, on full hook-ups. Dish washing takes the most water. When traveling we can go three days easy by skipping a shower every other day if possible and using paper plates and cups.
When we started out I put this flowmeter on the city water so we could tell who and what was using the most water.
Showers initially were using 10+ gallons each but we got that cut in half just by knowing about it.
HTH,
Ray
2020 Georgetown GT5 34H5
2020 Equinox Premier AWD 2.0L/9-speed
09-04-2020, 02:55 PM
Part-Time Campground Host
I was thinking about putting one on the shower hose, but DW nixed that.
Craig & Cath
Days camped since 2015(retirement): 1680
09-04-2020, 03:02 PM
Thank you Ray. I’ll check that out.
CH & Sharon Romine
09-04-2020, 03:05 PM
It installs in the wet bay. Just saunter out and look at the counter before and after. That's how I did it. Then we started a competition to see who could get it the lowest. We were down to about 3 gallons each.
Ray
09-04-2020, 03:15 PM
Ray
Yea I have one that I use when filling my FW tank. We are lucky in that we have two 35 gray tanks onboard, but that sometimes means two trips to the dump station with the tote.
Craig & Cath
09-04-2020, 04:37 PM
Your profile still says Avenger 20RD.
09-04-2020, 04:42 PM
Actually your new trailer is almost 29ft long.
https://forestriverinc.com/rvs/trave...fsx/260RT/4173
And it looks like your previous smaller trailer had more gray tank capacity.
09-05-2020, 01:06 PM
BMullins46
Why not just get a 35 gallon "blue" tank to drain your gray water into then take it to the dump station? Sure a much easier thing to do. you can leave it hooked up to the sewer drain port with the valve closed until you need to dump.
Bill Mullins
2016 XLR Thunderbolt 385AMP
2012 Ford F350 DW 6.7 Power Stroke
09-05-2020, 03:21 PM
35 gallons?
35 gallons is a LOT of weight. We have a 25 gallon tote, the kind with two little wheels at the back and a handle at the front. That's over 100 lbs to lift the handle off the ground, and a tough 25-foot drag through deep pea gravel before I can get to the golf cart (TV for the tote).
I'm in pretty good shape for a 75-year-old, but I wouldn't want to add 83 more pounds (10 more gallons) to the load.
Larry
09-05-2020, 06:04 PM
Tank capacity
Adding a larger tank is not usually possible w/o a lot of work. They are only so many tank sizes available and the space is usually maxed out. Only way to know is taking the bottom cover off and looking. Filling a 28 gallon tank in a day, does not sound right.
09-06-2020, 10:40 AM
BMullins46
To OP,
How about getting a sewer cap with a hose tap on it and running a 5/8" or 3/4" garden hose out to the parking spot for the golf cart leaving the gray water tote there so you don't have to pull it through the pea gravel. it would accomplish the same thing and eliminate some of the physical lifting for you. Of course I am assuming that it would be possible to leave the hose run out on a long term basis, having to rerun the hose every time you wanted to dump would be a real pain. I understand the physical limitations as I am your age.
Bill Mullins
09-07-2020, 09:53 AM
Confusing two posts
To OP,
Bill, I think you are conflating the Original Post with my post. The OP didn't menton age, golf cart, or pea gravel.
Original Post
My Post
I don't think the campground would permit me to leave a hose out.
It also would conflict with my usual process, based on the fact that the trailer is permanently sited on a site with no sewer connection: - Empty black tank into tote, pull tote to golf cart, empty tote, return
- Empty gray tank into tote, flushing hose, pull tote to golf card, empty tote, return
The conflict is that I'm not sure I could run the black tank through a garden hose without a macerator. That's getting kind of complicated.
I'm sort of using this as a bellwether. When I get too old to move that tote, maybe I'm too old for camping.
Larry
09-07-2020, 11:33 AM
I When I get too old to move that tote, maybe I'm too old for camping.
Nope, just get a tote where the handle can slip over a ball hitch and also a toad with a hitch receiver. You can camp until the take your license away.
Ray
09-07-2020, 12:42 PM
Not too old
Ray
Ray, the handle on the tote actually fits over a pintle hitch I put on the golf cart. although I have towed it with the SUV and trailer ball. The problem is getting it out of the very narrow aisle between our sideout and the next lot's cabin and deck. There's only an inch of clearance on either side for the tote--no way the cart could get back there.
It's a two-wheel tote (see first image). That means I have to lift and hold one end while pulling it, and lift it on end again when dumping. Classic physics tell me that the initial lifting force is 100 lbs (25-gallon tote). If I really did get too old to manage it, I could replace the tote with a three-wheel tote with side port (see second image) and eliminate the lifting. But I'm using this test (and another one) as a sign for when it's time to start easing off.
Larry
