Originally Posted by JDekker
I have a 2020 Heritage Glen Elite 36FL. My Grey 1 tank is not draining and backing up into the bathroom sink when running the shower - sensor shows 2/3 full. Black 1 tank drains fine, as do the forward grey and black tanks - no issues. There is more resistance on the grey lever than the black lever at the access panel. Don't want to tear into the underbelly or the access panel unnecessarily. Thanks for any assistance
I find the gray tank valve in the back very difficult to move (open or close). I lubricated the shaft once I finally got it pulled out (seriously, hard enough I was concerned I might break the handle!). That helped some.
When you do get the valve open you are saying it doesn’t drain then? If so, there is something blocking the pipes or the pull has come loose from the valve and it is indeed not draining.
That is a different beast - you would need to open the convenience center and track the cable to the valve.
