10-24-2020, 02:58 PM
Grey tank lever is stuck open
2020 GT5 31L5 - I drained the grey tank today and when it was finished I tried to close the lever and it won't close anymore. What can I do to close it? We are going on a boondocking trip next weekend!
10-24-2020, 04:34 PM
PhD, Common Sense
As a temporary fix, put one of those caps designed for the end of a hose on the opening to the gray tank.
10-24-2020, 04:57 PM
That's a great idea, thanks! After we get back from our trip we can bring it back to the dealer to look at, but we need it for this coming weekend, so a temporary fix will be great.
10-24-2020, 05:21 PM
PhD, Common Sense
You are most welcome.
Bear in mind that emptying that tank after use will be an issue.
10-24-2020, 05:23 PM
If that's a combined drain, won't that allow black water to back up into the gray tank when dumping?
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
10-24-2020, 05:48 PM
One of these might help. https://www.campingworld.com/twist-o...E&gclsrc=aw.ds
We have one on our rig just in case one of the valves starts leaking. It also prevents surprises when you go to dump. The valves can leak and put waste water into the pipe so that when you take off the cap, waste water will gush out before you can put the sewer hose on. (Don't ask me how I know.)
This valve will solve your problem temporarily.
2015 Dynamax REV 24TB class C
10-25-2020, 07:33 AM
PhD, Common Sense
If I understand this product correctly, it has both the fitting to connect to the gray outlet pipe and has the fitting to accept the sewer hose. (I can’t tell for sure since the picture shows only one side.)
If so, this has the benefit of capping off the outlet pipe and allowing for dumping (unlike my suggestion of using one of the hose caps).
This is a great emergency item that will be added to my regular RV supplies! Thanks.
10-25-2020, 10:00 AM
Both of my valves were beginning to bind up noticeably and the guy next to us suggested pouring a cup of vegetable oil into the empty tanks. I did and wow, I almost ripped the handle out because the valve moved so freely now.
Your problem is a bit different because the vegetable oil cannot sit against the entire valve seal (the travel path for the gate) but perhaps give it a try. It may lube part of the seal as the oil drains past so you can work the valve a bit.
I do have to add vegetable oil when the valves get a bit tight because this is not a permanent fix. For the black tank I can just pour it in. The gray tank is a bit different due to the P-traps in the sinks. I carefully pour two cups of vegetable oil into the closest sink drain, put the plug in, fill the sink with water, and pull the drain plug. The BAWHOOSH pushes the oil out of the P-trap and into the tank.
For both I let it sit for several minutes so the oil can travel to the drains.
Good luck,
Ray
2020 Georgetown GT5 34H5
10-25-2020, 10:20 AM
It fits between the outlet pipe and the cap you normally put on the end of the pipe. Basically, it twists on and you put the normal end cap on the other side. Comes with good directions that you probably won't need.
All you need is one 'leak' from bouncing down the road to decide this is a good idea. It should work for the OPs problem til he can get it fixed and afterwards.
10-25-2020, 11:32 AM
X2^^^
Works well, recommend you get one. Available from numerous places - on-line and dealers.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
10-25-2020, 12:45 PM
If you have a “brake cable” between the valve and the handle it is probably getting rusted. Spray WD40 on the entire length, to loosen the rust. Work it back and forth a few times, then spray heavily with silicone. May have to replace the entire thing.
2017 Puma Unleashed, 38 ft.
Dodge Ram 2017, 3500, Dually.
KG5TKV
Tiger Force Medic, 68/69
10-25-2020, 01:15 PM
I'm assuming the pull handle on a standard holding tank drain valve? If so, order one from Amazon for overnight delivery or two day delivery and replace it. The job takes about 20 minutes.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
10-25-2020, 02:42 PM
Google Lubricating RV sewer valves, there is a short video showing how to do this
2011 Berkshire 390RB (Front airbag upgrade & 275/80R tires)
10-25-2020, 10:54 PM
Valve cable stuck
If it’s the cable, I use Petrogel. It is a food safe lube, that will not wash off and doesn’t make a mess! End of problem! Works with hot water also!
10-26-2020, 07:29 AM
Another possible fix, even if only temporary, is to slightly loosen the 4 nuts that hold the valve in place. It helped me tremendously. The housing was too tight against the slidey “trap door.”
10-27-2020, 05:56 PM
I fixed it!
I ordered a new value unit from Amazon yesterday and it arrived today. I spent the last 30 mins or so taking out the old one and putting in the new one. It was easy. The tricky part was getting it back together because the weight of one side pulls down and you have to lift it and insert the bolt at the same time.
I tested it after I was done...no leaks, and it opened and closed perfectly. I saved the old one in case we need another one because it's brand new and I know what was clogging it.
I don't know how to post pictures on here to show you, but when I took the old one out, two big pieces of water-logged wood came out. That is what was blocking it from opening! I have no idea where the wood came from. The motorhome is a 2020, we bought it new and have only been on 3 trips, and obviously neither one of us put wood down the drain.
I also bought one of those caps that some people were talking about and put it on just to have.
Allison
10-27-2020, 06:50 PM
Allison
Debris falls into the tanks during drilling for the drain pipes and other assembly processes. They don't care! Just this past spring, after over 6 years, of use, a broken piece of PVC pipe plastic "O" ring got caught in the valves blade track keeping it from closing completely. Tell me where that came from since the nearest P-trap where these "O" ring seals are is under the bathroom sink & above the floor!
2014 Prime Time Sanibel 3250
10-27-2020, 07:52 PM
Allison
Open your recently received Welcome PM, click on the link to Forum 101 and follow instructions in post #7.
10-28-2020, 01:14 PM
Allison
Didn't realize this was a NEW unit. Curious - was there a reason you didn't take it back to the dealer (assuming it's still under warranty being it is a 2020 and you have only made 3 trips)?
