H20 heater issue
2014 Suburban h20 heater. Electric does not work on it. Only propane works. That's a different issue.
Inside switch was on as we needed hot water. After my shower, I shut the switch inside but left the propane valve open on the propane tank.
3 hours later, I hear the water heater fire up. I go inside and verified that I did turn the switch off. Water heater is running with the switch off.
I then go outside to shut the propane valve off. Gas stops flowing. I hear some clicks coming from the hot water heater. The left reset button was out so I pushed it in. The right switch did not change position when I pushed it.
Help.....is my inside switch bad? Is something wrong on the water heater? I am seeking help on how to fix this.
Many thanks.
Eaa
