Old 03-01-2021, 08:10 PM   #1
Hanging ClearSource from ladder
My Flagstaff 21DS has the ladder on the same corner as the water inlet so it was convenient to keep the filter system off the ground. I found two utility hooks at the hardware store and drilled a couple holes and bolted them on. It's secured with an old cable bike lock I had laying around. A 4ft hose and two 90* elbows fit perfect.
The hooks are positioned so that the bottom of the ClearSource frame sits on a ladder rung when the hooks are fully seated on another rung above.
When not using the filter, the hooks make nice handles and it fits laying down in the slide storage or even up front in the driver side forward compartment
ID:	248680   Click image for larger version
jbflag21ds is online now   Reply With Quote
Old 03-02-2021, 09:09 AM   #2
SeaDog's Avatar
Good job I relocated my filter to the bumper I would recommend when you disconnect for travel or any period sitting you pull the filters and allow them to drain and dry.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-03-2021, 01:33 PM   #3
Always Learning
That's a cool idea!
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 03-03-2021, 07:00 PM   #4
for sure. i always undo the water first and pull the filters out to drain as much as possible while I tear down a camp. Then i assemble it but barely, so there is air flow into the canisters. When I get home I pull it apart again and sun dry it
Old 03-04-2021, 05:20 PM   #5
Nice setup and they stay clean when it rains. I'm going to try it thanks.
BM Welder is offline   Reply With Quote
Old 03-04-2021, 05:45 PM   #6
That's a great idea!
2020 Flagstaff Micro Lite 22FBS
