Old 04-13-2017, 05:28 PM   #1
Help!! Can't find this mystery fitting...
Need help finding the fitting that's circled in the photo. It started leaking thanks to a park with surging water pressure and once we got to a better park, the damage was done. I sent the photo to a local supply store and the answer, no kidding, was, "Bro, I've never seen that before." It leaking right where the brass meets the plastic female connection.
Its obviously a slip fit brass elbow with a plastic female threaded connection to the back of my water heater but I am struggling to find a replacement!!
Thank you to anyone and everyone who might be able to help.
(2011 Coachmen Freelander 32BH)
Name:	Leaky fitting.jpg
RichieD15 is offline   Reply With Quote
Old 04-13-2017, 05:39 PM   #2
Iwannacamp's Avatar
If I had to guess...I say 1/2FPT swivel x 1/2" pex 90 deg. One could get a "shark bite" for the pex end if preferred.
2017 Puma 297RLSS
Old 04-13-2017, 05:41 PM   #3
Iwannacamp's Avatar
BTW you will have to clamp/crimp the new hose back to the valve on the other end of that short hose. Amazon is cheap on the clamping tool.
2017 Puma 297RLSS
Old 04-13-2017, 06:26 PM   #4
john5646's Avatar
If it's leaking at the swivel. Try replacing the cone washer inside. If they are overtightened the washer can push into the receiving nipple. If it's the crimp leaking then only one option replace.
john5646 is offline   Reply With Quote
Old 04-13-2017, 07:04 PM   #5
The other posters were right, it is an adapter from pipe threads to pex. there is a rubber gasket in it similar to a garden hose. hand tight is usually good enuf.
Concerned tax payer is offline   Reply With Quote
Old 04-13-2017, 07:06 PM   #6
10 years working for lowes and I hate plumbing. the red end is simple pex with a crimp ring the other grey threaded end i beleive is specific to campers/modular homes. Probably not going to find at a box store. (someone who really knows what they are doing might be able to rig a fix) may want to try a modular home parts/supply store if you have one in the area.
I have a place 15 min west of me that only deals in rv mechanical stuff. place like that would have for sure.
Kimber45 is offline   Reply With Quote
Old 04-13-2017, 07:18 PM   #7
Iwannacamp's Avatar
I'm not a betting person, but I would put a couple dollars on 1/2" FPT. They are all over RVs.
2017 Puma 297RLSS
Old 04-13-2017, 07:24 PM   #8
https://www.supply.com/shop?nid=7159...I-IaAuif8P8HAQ
johnbryanpeters is offline   Reply With Quote
Old 04-13-2017, 07:59 PM   #9
Originally Posted by johnbryanpeters View Post
See, there's proof that this forum works !!!!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-13-2017, 08:09 PM   #10
john5646's Avatar
Amazon has them. If it helps
Old 04-13-2017, 08:25 PM   #11
Brother Les's Avatar
Everyone should use a pressure reducer when using water hookups. Never trust the campgrounds water pressure.
You should also be able tighten the connection or unscrew it and add a new rubber washer inside the connection.
Brother Les
Old 04-14-2017, 01:21 PM   #12
RVdoctor
help can't find mystery fitting
Any place that sells pex should have this fitting. Hardware stores, RV stores, on line. Fitting may not look exactly like the one you have but will function just the same. The rubber seal can be purchased separately. It appears the previous installer used teflon tape on the fitting threads. There is no need to use teflon plumber's tape on this type of fitting because the rubber seal does the sealing.
rvdoctor is offline   Reply With Quote
Old 04-14-2017, 06:55 PM   #13
http://m.ebay.com/itm/1-2-PEX-x-1-2-Female-NPT-Threaded-Swivel-Elbow-Crimp-Fitting-LEAD-FREE-/391201511032?hash=item5b156d5678%3Ag%3AfW0AAOSwd0B VptBO&_trkparms=pageci%253A01d927dd-216d-11e7-8acc-74dbd180d34b%257Cparentrq%253A6edf305f15b0a6228615 51e6fff7544b%257Ciid%253A22
Gmar60 is offline   Reply With Quote
Old 04-14-2017, 07:04 PM   #14
tuckerdog1's Avatar
Buy 87 and get free shipping
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
Remember those that died for us. And remember who killed them.
tuckerdog1 is offline   Reply With Quote
« Fozue | Suburban WH »
