Old 07-23-2020, 02:37 PM   #1
Help finding fitting
Hey everyone, first post, first time pup owner. Just picked up a 2014 Rockwood 2280 BH and have been checking all the systems out. It appears it wasnít properly winterized as I have found a cracked water filter housing (already fixed) and also the trap for the sink is cracked. The trap is glued to the elbow that protrudes thru the wall to the outside. I have never seen a fitting like this with the extended external threads. I have found every other drain fitting/flush mount for this camper, but not this piece. Can anyone point me in the right direction?
tjkoen01 is offline   Reply With Quote
Old 07-23-2020, 02:40 PM   #2
Check a pool store for that grey threaded piece, it looks like a piece that I used on my pool filter.
wildcatter is offline   Reply With Quote
Old 07-23-2020, 02:41 PM   #3
Not that end, the other.
Old 07-23-2020, 04:28 PM   #4
Sorry, my bad.
Old 07-23-2020, 04:52 PM   #5
Put J.B.underwater weld on crack. Walmart in auto section , look like putty in a tube ,cut off a piece mush together apply. Off you go.
Thomas ho is offline   Reply With Quote
Old 07-23-2020, 05:02 PM   #6
Where is it broken? Maybe just buy another p-trap same size and replace just the broken section.
AFDON is offline   Reply With Quote
Old 07-23-2020, 05:17 PM   #7
The trap is glued to the elbow with the external threads. I think Iíve got a plan to fix it.
Old 07-28-2020, 11:18 AM   #8
I looked at those threads on pipe they look like they were made by a hand held pipe threader. I have threaded pvc pipe and they dont come out as clean as a foctory made pipe with threads.
Old 07-28-2020, 11:31 AM   #9
Did your plan work? If so, mind describing it? Might help someone down the line.
Old 07-28-2020, 11:41 AM   #10
That piece is made with the threads on it, the threads are perfectly formed despite how the picture appears. Definitely not cut with a pipe threader.
Old 07-28-2020, 11:59 AM   #11
I am working on rev 2...and not all the parts have arrived for rev 1!
My research led me to this piece from Amazon, this is what makes my solution possible.
http://LASCO RV281 Swivel Tray Plug ..._xwfiFb0RSC8MV
I ended up cutting the threaded part off of the 90 and cleaned up the threads. The part from Amazon threads onto it and adapts it to a 1 1/2Ē solvent weld socket.
From here it will be connected to a HEPVO waterless trap and then to 1 1/4 hose barb to connect to the sink. I will post pictures when I have it done.
Old 07-28-2020, 12:20 PM   #12
Head Rambler
Looks like you got yourself a unicorn there. The RV mfg might be able to help.
You might be able to build one that will work out of a standard P-trap and an ABS Plain to Threaded Nipple.
Gotta go campin!
Old 07-28-2020, 12:20 PM   #13
Iwannacamp's Avatar
Its called an elbow with flange... Is it 1 1/2"
2017 Puma 297RLSS
Old 07-28-2020, 12:43 PM   #14
I searched that and donít see anything that resembles what I have.
Old 07-28-2020, 01:10 PM   #15
Iwannacamp's Avatar
Here is one example...
https://www.lasallebristol.com/produ...lbow-w-flange/
2017 Puma 297RLSS
Old 07-28-2020, 02:03 PM   #16
Lol, where were you last week?? Could have saved me hours of my life!
Still canít find it for sale, but that is definitely it!
Old 07-28-2020, 03:38 PM   #17
Iwannacamp's Avatar
The closest contact to Louisville KY(assuming) is here
Tennessee
192 J.D. Yarnell Ind. Pkwy
Clinton, TN 37716
Ph: 865-463-2301
Fax: 865-463-2306
2017 Puma 297RLSS
Old 08-04-2020, 09:06 PM   #18
So here is what I came up with, pretty simple really Click image for larger version
