03-27-2020, 07:49 AM
Help! Keep running out of hot water and wife is not happy!
Hey everyone,
We're at a CG right now and each time we try to take a shower, the hot water runs out in no time at all. The water is piping hot at first, but quickly become lukewarm and then cold. The burner kicks on and stays on pretty quickly after starting the shower, so that is not the problem. I've checked - both inlet and outlet (hot) valves on the heater are fully open.
Before anyone suggests it, we've been RVing for decades and are pretty adept at taking Navy showers, so I know we are not burning through 6 gallons in a few minutes of on/off with the hot water knob.
As we stand there freezing in our birthday suits, the hot water will heat back up, so the heater seems to be functioning correctly, but it's almost as if there really isn't 6 gallons in there....2 gallons max if I had to make a guess. I get water out of the pressure relief valve when I open it as well, so the tank seems full.
Ideas? I figure if I call a mobile tech, he's just going to say it's functioning fine and take my $100.
Thanks!
Butch and Sharon
Goldsboro, NC
2020 Wolfpack 365Pack16
2018 Yamaha Star Venture TC in back
2020 GMC Sierra Denali 3500HD DRW
03-27-2020, 07:52 AM
Check your outdoor shower to make sure the valves aren’t turned on and the button on the spray head is turned off. This will cause your hot and cold water to mix.
Bruce
03-27-2020, 07:57 AM
What Nomad said.
If you have a second shower with the wand turned off and the faucets still on the hot and cold water in the system will mix. The outdoor shower is usually the culprit but any wand with a shutoff on the handle will do this.
-- Chuck
03-27-2020, 08:01 AM
Originally Posted by Chuck_S
What Nomad said.
-- Chuck
Yup! I tend to forget about those who are fortunate enough to have more than one shower inside of their RVs.
Bruce
03-27-2020, 08:04 AM
Just for giggles, make sure your bypass valve is in the correct position if you have one.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-27-2020, 08:06 AM
Check his edit to his OP.
Bruce
03-27-2020, 08:15 AM
I've never heard of a WH in a trailer with no bypass.. .
03-27-2020, 08:19 AM
Sorry gang - I don't know what I was looking at under there this AM. I do have a bypass set up. PDI guy said there wasn't one and for some reason, after 5 RV PDIs during my life, I trusted him!
Outside shower is not the issue - checked the knobs. Thanks for the heads up though. Never heard of that one before. Good knowledge to have.
I am going back under to check the bypass valves.
Butch and Sharon
Goldsboro, NC
03-27-2020, 08:21 AM
See my comment in my follow up. My first TT did not have one and I had to install. During my PDI on this the guy said there wasn't one. I found that kind of hard to believe, but in the drenching down our we were in, I decided not to look to verify.
Butch and Sharon
Goldsboro, NC
03-27-2020, 08:30 AM
Current set up. Everything looks correct. When I rotate wither valve, we get no flow from hot water faucets, so that tells me all is working correctly with the bypass, correct? No idea why pic is 90 degrees out.
Butch and Sharon
Goldsboro, NC
03-27-2020, 08:39 AM
[QUOTE=Chuck_S;2294675]What Nomad said.
Will using the shutoff on the shower head we are using cause this? I'm use to it giving an initial blast off cool water when you hit the button back on, but this is full up no hot water, i.e., it never comes back hot until you stand there 10 minutes waiting for the it to heat back up.
Butch and Sharon
Goldsboro, NC
03-27-2020, 08:42 AM
Kanadian Kamper
My system has the 3 valve design for bypass, but I see how yours is designed.
That said, if that’s the normal position for your valves for everything to work right in your photo, then if you were to turn BOTH valves 90 degrees from the positions shown, I believe you should then NOT get any from your hot water taps.
Have you verified that?
Also.....is this the first time you’ve ever experienced this problem with your rig?
Ken and Terry
03-27-2020, 08:50 AM
One test you can try; fill a 5 gallon bucket with hot water only. This will help determine how much hot water you are getting.
Until the problem is solved you have 5 gallons to wash with and you'll be able to find the recovery time for the next shower.
03-27-2020, 09:00 AM
Ken - yep. Switched the positions through hall 4 possible combos and this is the only way we get water. Only the second trip in the rig. We don't recall it happening on the first trip, but it was so darn cold in the winter, we were in and out of the shower in a flash!
Butch and Sharon
Goldsboro, NC
03-27-2020, 09:01 AM
Great idea. When we get back this afternoon I plan on measuring how much actually comes out of the faucet.
Butch and Sharon
Goldsboro, NC
03-27-2020, 09:02 AM
Have you tried releasing the pressure valve on the tank to make sure it is totally filled with water? Be extremely careful as hot water may come out if it is full. I'd suggest depressurizing the system first, open the valve, then turn your water (or pump) back on.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
03-27-2020, 09:21 AM
Bruce
Same with the inside shower.
03-27-2020, 09:30 AM
Did that too. Water come out immediately.
Butch and Sharon
Goldsboro, NC
03-27-2020, 09:36 AM
Kanadian Kamper
We’re running out of ideas here.
I’m in agreement at this point. Somehow, see if you can capture a known quantity of hot water, and see when it runs out to verify your 6 gallon unit for capacity.
Am I right in assuming your heating tank is propane only, and not electric too?
Ken and Terry
03-27-2020, 09:57 AM
If you have a Shower Miser, have you turned it off while showering? If not, you may be sending a lot of your water to the FW tank.
2011 Traverse LT, 3.6L, FWD
