10-29-2020, 04:37 PM
Help: Need toilet supply fitting
I have a Microlite 2509S that developed a water leak near the toilet this past trip. Sometimes it is a few drops or a larger stream overnight. I found the supply line cross threaded from the factory so I corrected that. I also replaced the flush valve on the Dometic 300 toilet and replaced a semi-loose hose clamp on the hose that connects to the toilet.
I can't test it now as it is winterized but I would like to get the connector that hooks to the toilet valve in case it leaks next Spring. What they use is a right angle 3/8" barbed fitting to a toilet valve fitting. This fitting has a flat washer in it, not a beveled connection like most of the other water connections in the RV.
So where can I find a connector with a flat washer for the toilet end and a 3/8" barb fitting to connect the plastic water supply to the toilet. I can find right angle barbed connectors but nothing with a flat washer to mate to the toilet.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
10-29-2020, 04:44 PM
1/2 pex by 1/2 supply any angled faucet supply with work . these are not 3/8
10-29-2020, 06:00 PM
Not PEX feeding the toilet
I know most RVs use a PEX feed for the toilet but mine is a flexible plastic line with cross fibers in a diamond shape running through the white tubing. Kind of like a heavy duty shower hose. This is why there is a barb fitting and a hose clamp on one end and a screw on connector for the toilet end.
My trailer uses the flex line for connecting from the water tank to the pump, feeding the sinks, city water to the pump inlet, connecting the water filter, etc. PEX is used in the vicinity of the water heater where valves are involved.
I might be able to use a standard toilet supply hose but it needs to be at a right angle because the hose comes out to the right side of the toilet and then makes a right angle to connect to the toilet.
Thanks for the suggestion - just won't work in my case.
Ham Callsign KD7UM
10-29-2020, 07:34 PM
you should be able to get a plastic 1/2 pex by 1/2 faucet supply . the plastic fitting is just a tad smaller and should fit the vinyl hose with a clamp or pex clamp to secure . pictures always help .
10-30-2020, 02:58 PM
How about...
Larry
10-30-2020, 03:00 PM
You can buy flexible RV hose like you described and attach PEX fittings to it including the PEX clambs. Used all the times in various places in your trailer including your water pump.
10-30-2020, 03:14 PM
10-30-2020, 04:47 PM
Originally Posted by wvram
Exactly / plus you can get in plastic if needed . prefer brass
10-30-2020, 07:17 PM
10-30-2020, 10:41 PM
Resolution with picture
Several of you put me on a track that will work. I am including the picture I should have posted in the original request. My apologies for making you guess what I have.
The fitting needs the washer in the female side to seal against the toilet fitting so the right angle connector, like one that goes on the water pump, will not work. I am going to get a right angle toilet to PEX barb connector and that should work.
I did repressurize my system with RV antifreeze and the original fitting is not leaking but it was cross threaded at the factory so I am going to change it out in the spring. Again, thanks to everyone.
Ham Callsign KD7UM
