Old 09-10-2020, 12:08 PM   #1
dougschne's Avatar
Help with black tank valve rod
Looking for thoughts suggestions. I have now lost the valve rod on my black tank waste valve twice. Both times on the way to the same casmpground! Maybe shouldn't go back there
Anyway, has anyone experienced this and what was your solution. Don't mind buying a replacement rod but hate it when I'm at the campground for the weekend with no way to open and dump tank.
Thanks.
2014 Sabre 33CKTS purchased 01/18
2009 Ford F250 SD 6.4L TD "FrankenFord" No Longer
2019 Ford F350 Lariat SD, 6.7 TD
Check out my Blog "A Grande Tour" about our travels and other writings! agrandetour.com
dougschne is offline   Reply With Quote
Old 09-10-2020, 12:56 PM   #2
its threaded. put red loctight thread sealer on threads and re install
Thomas ho is offline   Reply With Quote
Old 09-10-2020, 01:48 PM   #3
dougschne's Avatar
That's kinda what I figured. It's hard finding a replacement rod. I can find the extensions but you need the original rod to add the replacement to. My valve is also under the belly pan so a bit of a pain to get to. Thanks for your reply.
black, black tank, tank, valve
