I am in the planning stages of possible moving a toilet. May water supply line will be to short and I might be in need of a pvc nipple to join two lines. Any recommendations would be appreciated.
You are going to need to provide more information. Are you going to try to extend PEX tubing or nylon braided tubing? If it is PEX, I would recommend Sharkbite push-to-connect:
You are going to need to provide more information. Are you going to try to extend PLEX tubing or nylon braided tubing?
Nylon Braided tubing. Female on both ends. Also need to find a elongated slow close wooden toilet set and lid for a 320 Dometic. Thank you for the reply.
HOw far are you moving it? Is not the drain access going to be a problem?
