Old 03-21-2017, 05:23 PM   #1
Hose drip when hooked to city water
Have a constant drip from this hose when hooked to city water. Cannot find a cutoff valve? Any ideas?
Dannyw is offline   Reply With Quote
Old 03-21-2017, 05:27 PM   #2
SeaDog's Avatar
there are two in the pic which are you talking about.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-21-2017, 05:33 PM   #3
Longer hose with no valve drips. Other with valve is fine.
Old 03-21-2017, 05:45 PM   #4
far north Alabama
formerFR's Avatar
is your water tank full, or overfilling? this looks like an overflow tube...
or
it's one of your 'Low Point' drains that is not closed tight
The Turners
'14 Thor Palazzo 33.3 compact diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada - Hiawassee,GA (and '14 Gulfstream Amerlite and '07 ForestRIver Rockwood) : )
formerFR is offline   Reply With Quote
Old 03-21-2017, 05:47 PM   #5
Looks like water tank is full, could this be overflow drain?
Old 03-21-2017, 05:55 PM   #6
Flybob's Avatar
If the back flow valve in the water pump is not seated well the city water will fill the FW tank and eventually come out the overflow. Try the following
Disconnect city water.
turn off water pump if on.
Open faucet and let it run until water stops
turn on water pump allow water to come out faucet.
Shut off faucet and allow pump run until it stops
shut off water pump
reconnect to city water.
You should also drain some of the FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-21-2017, 06:16 PM   #7
Okay Thanks, I will give this a try!
Old 03-21-2017, 06:24 PM   #8
Flybob's Avatar
To prevent this from happening, do not use water pump when connected to city water.
TST Tire Monitors
2 100W solar panels
Old 03-21-2017, 08:29 PM   #9
2007 WildCat 32QBBS
18CrewDually's Avatar
Flybob has it covered very well.
Of course if it continues then the back flow preventer (check valve) will probably need to be cleaned out or replaced.
18CrewDually is offline   Reply With Quote
Old 03-21-2017, 08:38 PM   #10
Ford Idaho's Avatar
Yes.
city water, water
