Originally Posted by Thomas ho
cut off with a DREMEL CUT OFF WHEEL. you can rent a ring compresser tool at home depot .two types ones like you have and totally round that compress.i would cut off, worm clamp back on. get good worm clamps not at walmart.
Why waste the cost of a Dremel wheel. A screwdriver will pop off a pex clamp and no danger of damaging pipe or fitting.
There are at least 20 YouTube video's showing how.
Worm clamps are terrible and are often the cause of leaks themselves, especially if used on hose.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
