01-01-2022, 07:09 PM
Hot water drain plug
I went( 30 miles one way )out to the storage lot to drain my hot water heater, taking a 15/16 th and a 7/8 th socket. Both Too Small. I was surprised as that has covered it in many prior RV;s This is a new FR 36 foot tow, could anyone tell me the correct size socket to remove the plug/annoyed rod in order to drain the hot water heater tank
Thank You.
Wayne
01-01-2022, 07:13 PM
To my memory I think it's 1-1/8 or 1-1/16 socket
01-01-2022, 07:38 PM
I bought a cheap chinese spare that stays in my camper, never look at the size. That way my good set stays whole.
01-01-2022, 07:42 PM
1 and 1/16th
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
01-01-2022, 07:47 PM
keith52 has it...1 1/16" socket
01-01-2022, 07:53 PM
Or 27 mm.
01-02-2022, 03:18 PM
WH drain plug socket size.
I use a 10 inch adjustable wrench, fits ever time.
01-02-2022, 04:18 PM
1 /16 but also get an extension!
01-02-2022, 04:24 PM
Actually 1 1/16" as stated above.
1/16 is kinda small!
Mr Dan beat me to it.
01-02-2022, 04:26 PM
Once you've got the size figured out...Mod it!
2018 Sunseeker 2400R MBS (w/dinette)
2013 Honda CR-V toad
01-02-2022, 04:33 PM
Originally Posted by TomAR
Is that an Attwood? My guess is the op has a suburban with an anode rod. Won’t work.
01-02-2022, 04:57 PM
Paul & Dianne
This. Don't forget the extension, really hard to impossible otherwise. You can use an adjustable wrench, but a socket is a whole lot easier. Also, make sure you've opened a faucet in the camper and depressurized the system first. Ask me how I know...
2019 Rockwood 8299BS
2019 F350 Lariat 6.7 CC SRW
01-02-2022, 05:31 PM
Plastic plugs? what is it with the plastic plugs
01-02-2022, 05:55 PM
Usually found on Atwood WH and they don't corrrode
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
01-02-2022, 06:22 PM
plastic plugs
Outer edges are really too soft so it may strip too easily and have to get the socket on it just right
01-02-2022, 06:26 PM
Pipe threads seal by the use of tapered threads.
If you are tightening a plastic pipe plug to the point you strip the outer edges, you are tightening too tight.
The plastic plug threads will seal well enough long before you'd strip the plug.
01-02-2022, 08:33 PM
I used a 3/4” steel ball valve. Allows me to drain the tank without getting hit with hot water and can attach a drain hose if it want.
DERNORD 3/4 inch Stainless Mini Ball Valve NPT
2019 Freedom Express 248RBS
2012 F150 Supercrew 4x4
01-03-2022, 01:22 AM
How do you do that with the anode rod
2011 Flagstaff 831 RLBSS
01-03-2022, 09:51 AM
Drain Them Rusty HWH.
Yeppers, you need a 1 - 1/16 socket, an extension, if this is the first time you may need a breaker bar instead of a ratchet and when you reinstall for the winter, after it drains of course, hand tight only. Just tight enough to block the hole. Spring time do not forget to remove plug, apply rector seal, and then tighten enough to stop it from leaking.
