05-10-2018, 01:02 PM
#21
I printed this out and tape it to my hot water heater so I don’t forget next year
Let’s go camping!
05-10-2018, 01:20 PM
#22
Originally Posted by
Mch5jdm
Hey, that just gave me a thought. I might could make some printable files for our library on things like this, that members could download and do just like you did.
2011 Flagstaff 831 RLBSS
05-10-2018, 01:37 PM
#23
Are they really three way valves just 2? I have never seen one. What happens when you turn one 180 degrees?
05-10-2018, 03:57 PM
#24
cavie
They only turn 90 degrees.
2011 Traverse LT, 3.6L, FWD
05-10-2018, 04:00 PM
#25
wmtire
Great idea!
Let’s go camping!
05-10-2018, 04:31 PM
#26
rockfordroo
So why are we calling them a 3 way valve?
05-10-2018, 09:06 PM
#27
cavie
Well technically it’s a 3-way L valve. Meaning it has 3 holes but only can exit 1 direction.
Let’s go camping!
05-10-2018, 10:45 PM
#28
cavie
"We" aren't calling them 3-way valves. The
industry call s them 3-way valves; because they have 3 ports (i.e., connections).
Here's the link I provided in Post #4, again:
https://assuredautomation.com/3-way-ball-valves/
As Mch5jdm says, they're 3-way "L" valves, but if you look at the various versions in the link above, you'll see that there are also "T" versions.
10-23-2019, 09:50 AM
#29
hot and cold water tank valves
i'm winterizing my 2020 FR Cherokee Grey Wolf Limited 26DBH. Found the hot water heater tank but i only see two valves. If i close these two valves does it act like a bypass valve? Since i don't have a bypass.
10-23-2019, 11:33 AM
#30
If you have two "3-way" valves, with hose between them (the bypass line), then, YES. Turn both valve handles 90 degrees and you're good to go. See the pic in post #17.
10-23-2019, 11:46 AM
#31
Which photo looks like the one you have?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
» Recent Discussions
