08-26-2019, 09:14 PM
Hot Water Heater UhOh
Came back in Sunday Forgot to turn power off the WH. Tank still has waster. Plugged in to 110V cord.
Think I might have done damage?
BT
Bluetick1955
2015 Cherokee 264L Limited
08-26-2019, 09:21 PM
BT
No, as long as there is water in the tank. It would take a long time to evaporate enough water to expose the heating rod.
08-26-2019, 09:30 PM
You should be fine as long as the water covered the element. If not a replacement element is not too expensive and readily available.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-26-2019, 09:37 PM
It only ran when the temp got below the lower limit of temp sensor. I know the water in our WH down at cabin is still warm after not being there for 2 weeks.
08-26-2019, 09:58 PM
Just a member
Ditto
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
08-27-2019, 07:33 AM
Thanks. What I thought just looking for some reassurance
Bluetick1955
08-27-2019, 01:33 PM
As long as there is water in the tank, it's just like at home when you go out for a weekend. You don't switch off the HW at home do you?
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
08-27-2019, 02:22 PM
Should be fine if water was in it.
That said, my replacement water heater element was about $20 and the huge socket for it was about $8. Mine got run dry after dewinterizing. Looking on the bright side, I discovered that the water heats 2 to 3 times faster with gas on my water heater
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
08-27-2019, 07:53 PM
Around $10 at Amazon
Elements are around $10 at Amazon.
Larry
08-28-2019, 02:38 AM
BT
NOPE!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-28-2019, 05:36 AM
NH Maple Maker
I did that myself after a weekend trip. I hadn't drained the wh and there wasn't any damage. I didn't think about it and turn it off until 3 days later.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
