09-20-2020, 05:11 PM
Hot water in toilet ??
Started testing out water system and when hooked up to city water the left handle in shower is cold and the left is hot. When I turn on the pump then it switches to left being hot and right being cold. The toilet even flushes hot water. I’m assuming something isn’t right! From what I can see the pump does run into the cold line so not sure what’s going on.
09-20-2020, 06:27 PM
I'm a little confused (but that's easy to do)!
I assume you mean that on city water the left handle is cold and the right is hot, and on pump they switch to normal (Left hot, Right cold).
Sounds like the city water is hooked up to the wrong line.
How old is the RV?
Gotta go campin!
09-20-2020, 06:38 PM
is your 'city' water shut off when you use the rv pump?
Brother Les
09-20-2020, 06:47 PM
How old is the RV?
Ozark 1650bh 2021
09-20-2020, 06:55 PM
No when we were using the water from our fresh tank we weren’t hooked to our city water hose
09-20-2020, 07:11 PM
We have other threads on this same occurrence. Let me see if I can find you some for the causes/cure.
2011 Flagstaff 831 RLBSS
09-20-2020, 07:14 PM
Happened to me, probably my thread the poster above is thinking of. Ultimately what happened is the city water connection is plumbed into the hot water side of the system. I was able to get to my connections and fix it.
I’ll find my thread and link it here.
Hot/Cold Switched?
https://r.tapatalk.com/shareLink/top...ink_source=app
09-20-2020, 07:20 PM
Since it's a 2021 I would let the dealer figure it out.
If you want to work on it a little you could pull the city water inlet or access it from the inside of the RV and see which line it's hooked to. You may have to remove a panel inside a cabinet to see the backside of the city water.
Gotta go campin!
09-20-2020, 07:22 PM
Hot/Cold Switched?
Yep, yours was definitely one I was referring to. Thanks for posting and saving me the search.
Here is another thread or two on the RV's being plumbed wrong from the factory:
https://www.forestriverforums.com/fo...ch-154002.html
https://www.forestriverforums.com/fo...et-105503.html
09-20-2020, 07:27 PM
Hmmm. Could the outside shower valves be open and bypassing?
2017 Puma 297RLSS
09-21-2020, 02:00 PM
Bama rambler is right you should let the dealer fix this because if you break something or find its more involved than you thought and bring it to the dealer he will probably say you broke and refuse to work on it under warranty. Go thru the rig completely find any other major gleaming issues and bring it back to the dealer. Be ready but, some dealers are great and some, will lets just say less than stellar. Let us know what happens.
09-21-2020, 03:05 PM
I wonder if they hook up the toilet to the hot water
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
