Originally Posted by James.Bolton
Hi all,
My 2004 fr wildwood le 22t only has one valve the hot water tank is that a correct item for this trailer?
As far as bypassing the water heater, the bypass system can consist of one, two or three valves. Yours just has one and that is correct as there will be a one way check valve on the hot water output line.
This thread may help explain (post #5 especially):
https://www.forestriverforums.com/fo...st-103381.html
BTW, from your pic in your first post, your hot water tank is currently bypassed with the way the valve is turned.
