Old 09-24-2020, 07:26 PM   #1
Hot water tank....
Hi all,
My 2004 fr wildwood le 22t only has one valve the hot water tank is that a correct item for this trailer?
James.Bolton is offline   Reply With Quote
Old 09-24-2020, 10:12 PM   #2
wmtire's Avatar
Originally Posted by James.Bolton View Post
Hi all,
As far as bypassing the water heater, the bypass system can consist of one, two or three valves. Yours just has one and that is correct as there will be a one way check valve on the hot water output line.
This thread may help explain (post #5 especially):
https://www.forestriverforums.com/fo...st-103381.html
BTW, from your pic in your first post, your hot water tank is currently bypassed with the way the valve is turned.
2011 Flagstaff 831 RLBSS
Old 09-24-2020, 10:25 PM   #3
I do believe that is the first "One Valve System" I've ever seen. mine have always been two or three valves.
TheWolfPaq82 is offline   Reply With Quote
Old 09-25-2020, 09:08 AM   #4
Thank you for the help. I am sure I’ll have more to come.
Old 09-25-2020, 09:18 AM   #5
Chuck_S's Avatar
Mine is a one-valve system. Just point the handle to where you want the water to go.
As noted the tank is bypassed on the photo.
-- Chuck
2006 Roo 23SS behind a 2017 Ford Expedition
Chuck_S is offline   Reply With Quote
Old 09-25-2020, 09:31 AM   #6
? Where is the check valve?
Is the T a check valve. The check valve would have to be in the line from the bypass to the tank.
tomkatb is offline   Reply With Quote
Old 09-25-2020, 09:34 AM   #7
nomad297's Avatar
It is integral to the nipple on the hot side of the tank.
Bruce
nomad297 is offline   Reply With Quote
Old 09-26-2020, 07:05 AM   #8
wmtire's Avatar
The internal check valve (sometimes referred to as a backflow preventer or a one-way valve) is in the threaded nipple coming out of the hot water output line at the water heater as Bruce stated above. The check valve only allows water to flow one way, which is out of the water heater. When the actual bypass valve is used, then water cannot backflow into the tank from the hot water line due to the check valve
These pics may help
ID:	239984   Click image for larger version
Old 09-26-2020, 08:56 AM   #9
Of note, a check valve, unlike a manual valve, maintains pressure in the hot water system independently of the cold water. The only way to release the pressure is via the HOT low point drain, or a hot water faucet.
Fred W
pgandw is offline   Reply With Quote
hot water, water tank, water, tank
