Old 10-07-2020, 10:22 PM   #1
Hot Water Tank Leak
2016 Wildcat 28SGX
Found a small leak at my water heater water inlet. Never realized it until I noticed the underbelly sagging some. Made a small hole and water streamed out.
After fixing the leak do I need to pull the underbelly down ? Is there some type of insulation that could have gotten wet? This was a really slow leak. I think the hose clamp was not clamped good from the factory. Thanks
WildcatAR is offline   Reply With Quote
Old 10-08-2020, 08:56 AM   #2
SeaDog's Avatar
You could cut a U shaped flap in the coroplast with the rounded part facing forward and inspect to see if it is wet under there after inspection close the flap using foil tape.
Retired Navy
2016 Flagstaff 26 FKWS
hot water, leak, tank, water, water tank
