Old 05-28-2017, 07:40 AM   #1
Hot water tank not heating water
Have a 2017 coachmen. Have electric heater on. Also gas to heat water. Need both to heat water. Hot water runs out while showering never had this problem with my 2001 Dutchmen. Can't find any info on electric heater wattage
davetech69 is offline   Reply With Quote
Old 05-28-2017, 07:42 AM   #2
AquaMan's Avatar
Your crossover valve is open.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-28-2017, 07:53 AM   #3
wmtire's Avatar
X2
See if this thread may help that we keep as a sticky at the top of the plumbing subforum:
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 05-28-2017, 07:59 AM   #4
No it's closed. I would think the electric would be enough to keep up then gas it it couldn't. Once water runs cold the gas comes on then heats water right up within 5 mins. Guess my old trailer had a higher wattage heater. Going to call dealer on Tuesday.
Old 05-28-2017, 08:05 AM   #5
wmtire's Avatar
You may want to check the crossover valve again or perhaps if you have an outdoor shower, that the taps are shut off, and not just turned off at the handheld shower wand.
Either one allows cold water to be drawn into the hot water line, thus you do not have hot water for long until the cold water mixing in lowers the temp. This is a common thing when people state they don't have hot water for very long.
Posts #1 and #3 in the link I provided above may help. It's easy to mistake the position of the crossover valve, since the line it's on is vertical.
Old 05-28-2017, 08:17 AM   #6
Turn the electeic gas and water off. Drain the HW tank. Flush it out, turn on water, go inside turn on the hot side of a faucet. Wait for a steady stream of water. Turn on electeic and gas. Wait 30 minutes and see what happens. I suspect you have a big air bubble in the HW tank. Yes, you need some dead air space, but too much and what your describing can happen.
donniedu is offline   Reply With Quote
Old 05-28-2017, 08:41 AM   #7
Sounds good. I'll try that thanx
Old 05-28-2017, 08:46 AM   #8
KyDan's Avatar
We still think you probably have partially open bypass valve.
In rare cases folks have found the valve defective and the handle wasn't
turning the valve correctly.
IF you open the outside metal hatch at your water heater the brand
and model will be found inside. Wattage of heater is most likely 1400-1500
watts but we can't be sure unless you provide make and model of WH.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-35
Old 05-28-2017, 11:04 PM   #9
New TT Owner
We tried everything with ours not heating on electric. Took it to the camper hospital this weekend (back to dealer) for it to be checked out.
Lovestogo is offline   Reply With Quote
heating, hot water, tank, water, water tank
