Old 07-30-2021, 04:35 PM   #1
Hot Water Toggle switch is stuck
I have a 2015 Forrest River Blue Ridge 3025RL. The electric toggle switch on the hot water heater on the outside of the 5th wheel is stuck in the "ON" position. Any way to free it up so that I can toggle it to the "OFF" position? I don't want to force it and it stay in the "OFF" position, but I'm afraid that I will forget to put water in the heater before I hook it up and burn up the element. Thanks......
3nails is offline   Reply With Quote
Old 07-30-2021, 04:43 PM   #2
force it off , but have new switch handy if needed . amazon has them
MR.M is offline   Reply With Quote
Old 07-30-2021, 04:46 PM   #3
wmtire's Avatar
This actually happens a lot. You can easily go inside the RV and in the electrical panel, turn off the circuit breaker to the water heater. You can use this circuit breaker as an on/off switch till you replace the switch outside.
See this thread link below
https://www.forestriverforums.com/fo...ml#post2317264
2011 Flagstaff 831 RLBSS
What if UFO's are just billionaires from other planets?
Old 07-30-2021, 05:05 PM   #4
Kanadian Kamper
kenandterry's Avatar
Yup. Those cheap switches melt a lot and lockup. Use the breaker inside like mentioned above, until you get a replacement.
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 07-31-2021, 01:25 PM   #5
BobHanke's Avatar
Check the electric heat element also.
BobHanke is offline   Reply With Quote
Old 07-31-2021, 05:39 PM   #6
NXR
NXR's Avatar
If this is a Suburban and it's really a rocker switch and not a toggle switch, I bought a spare from Amazon. That means mine will never fail!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 07-31-2021, 07:18 PM   #7
Did you try a little WD 40? I would before forcing it. That may free it up until you can get a new one. Good luck.
dave1650 is offline   Reply With Quote
Old 08-01-2021, 08:58 AM   #8
I wouldn't try this without making sure the power is off. Then let it dry and use a nonconductive contact cleaner afterwards.
glen1971 is offline   Reply With Quote
Old 08-01-2021, 09:51 AM   #9
Kanadian Kamper
Ray
Having a spare is handy, but…….
Someone once said “never say never”.
Ken and Terry
Old 08-01-2021, 10:31 AM   #10
DouglasReid's Avatar
My solution would be to leave it alone, use the Circuit Breaker and be done with that POS switch
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 08-01-2021, 10:33 AM   #11
NXR
NXR's Avatar
Personally, I would not try WD-40 at all. When the switch fails it's because it got hot and melted internally.
You're messing with 120 volts AC on that switch. Would you try to free up a sticky house light switch with WD-40? If not, do not try it on the water heater either.
As someone else noted, for now just flip the breaker inside for the water heater. Not fuse, the breaker.
Ray
Old 08-01-2021, 10:35 AM   #12
NXR
NXR's Avatar
Seriously? Haven't you ever had a problem, decided to carry a spare, and then never had the failure again? It works!
Ray
Old 08-01-2021, 02:33 PM   #13
When our switch was stuck "on", it wasn't on. Wound up getting it replaced.
Old 08-01-2021, 03:31 PM   #14
WD 40 is nonconductive.
Old 08-01-2021, 03:47 PM   #15
As mentioned, the switch sticks because it melts from not being able to carry the load of the electric element. It has nothing to do with needing lubricated or moisture displacement.
As was suggested early on , have a replacement ready and use the breaker until you get one. If you force it, you'll need to replace it right then or connect the wires together as it will be totally useless.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 08-01-2021, 03:56 PM   #16
Just Tryin' to Help
cboss's Avatar
Ray
Wanna sell your spare?
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is offline   Reply With Quote
Old 08-01-2021, 08:36 PM   #17
force it off
Mine did the same thing when it was pretty new. I bought the exact replacement from an RV dealer and it was doing the same thing. It will shut off. you won't hurt it. It just pops right out with a small screwdriver or butterknife or something like that if you want to replace it.
TGO Bill is offline   Reply With Quote
hot water, switch, water
