Old 03-23-2020, 12:09 AM   #1
How long can you keep water in the tank?
I'm new to trailers and was wondering how long you can keep the fresh water tank full before having to add some sanitation.
Chewman is offline   Reply With Quote
Old 03-23-2020, 12:35 AM   #2
2 weeks if the tank was sanitized prior to filling and the correct hose was used and the water was of good quality.
These are guidelines, others may have different experiences.
myxkp is online now   Reply With Quote
Old 03-23-2020, 11:45 AM   #3
Trailer Park Supervisor
NJKris's Avatar
CDC guidelines are for 6 months if water is kept in cool (50-70 deg F) dark place (out of direct sunlight), and things were sanitized before fill up.
NJKris is online now   Reply With Quote
Old 03-23-2020, 12:02 PM   #4
Canadian Member
I dump my system if its going to sit for more than 2 weeks. Drain the fresh water tank, the hot water tank and all the water lines. Some will say its overkill but that's what I like to do. I don't want warm stagnant water sitting in my trailer for too long.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 03-23-2020, 12:11 PM   #5
Ditto for me also.
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is online now   Reply With Quote
Old 03-23-2020, 12:53 PM   #6
Villagerjjm's Avatar
In warmer weather you may run a risk of amoebic dysentery if the water sits too long in the tank without additional sanitizer.
Villagerjjm is offline   Reply With Quote
Old 03-23-2020, 01:09 PM   #7
NJKris's Avatar
Amoeba has to get in there somehow, it is a living organism. A properly maintained system should not be susceptible to such an infection unless the water source was sketchy to begin with.
Old 03-23-2020, 01:18 PM   #8
That is true, and the key is proper maintenance, like you stated. As for how the amoeba get in there.... take a factory fresh unopened bottle of water and leave it outside for 3 or 4 weeks. After that time, I dare you to go out, open it and drink it down. I double-dog dare you! 🙄
Old 03-23-2020, 02:01 PM   #9
Tundra 2014
Water
I dump mine after every trip. If it sits in there for more than a couple of weeks, get a taste and DW makes us go to bottled till I sanitize.
Tundra 2014 is offline   Reply With Quote
Old 03-23-2020, 02:22 PM   #10
Water in tank
We fill in the spring, camp a couple weekends a month. add water as needed and drain in the fall.
2015 Forester 2901
2005 Scion XB
RacerRalph is offline   Reply With Quote
Old 03-23-2020, 03:19 PM   #11
well I guess I have been wrong all these years. no one has gotten sick yet. I drive it around every few weeks so it isn't just sitting there.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 03-23-2020, 05:01 PM   #12
Grapehound's Avatar
Careful is smarter with wager
(Sorry--title intended was "Careful is smarter with water," not wager)
Like many, I dump the balance of my fresh water water tank when I arrive home. I only travel with a few gallons for on road use anyway.
I am not so pressed for a few gallons of water that I need to save it for months in hot weather. (I could use it on the flower garden, I guess.) If the RV sits for some weeks in warm weather, I sanitize again with a bleach solution before heading out, since the water lines are still full of "old" or stagnant water, even if you drain your fresh water tank.
One consideration not mentioned is that your water may have a longer "shelf life" if you filled from a chlorinated 'city' water source. That said, there seems no advantage in my mind to use older, stagnant water, rather than at least refilling with fresh water, even if you don't resanitize.
Your innards won't be happy if you take a chance on "dirty" water and choose wrongly.
Just my thoughts.
Larry
Grapehound is offline   Reply With Quote
Old 03-23-2020, 05:02 PM   #13
Lots of answers so here's mine: End of season, I drain and refill with bleach based fresh water, making sure to run through the system. Begining of year, I drain, refill, drain and refill, and run thru the system. Then I refill with good fresh water. We have extremely good tap water.
JimMorrell is offline   Reply With Quote
Old 03-23-2020, 05:06 PM   #14
Thank you all for the information. I looked in the owners manual and see to properly sanitize you need to connect a water connection and add the chlorine. Will someone explain why that is necessary vs just adding the chlorine to the fresh water tank.
Thanks again to all, there is a lot to learn!
Old 03-23-2020, 05:08 PM   #15
NMWildcat's Avatar
If you are like a lot of us, you can't actually drain all the water out of your tank. My tank has a pretty good bulge in the bottom that holds several gallons of water. I can pump it, drain it, leave the drain open while traveling hundreds of miles, and there is still water in there.
So I just disinfect it with Clorox ever so often and don't really worry about it.
We use ours often enough now that we always leave at least 15 gallons or so in there.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 03-23-2020, 05:55 PM   #16
I have an earlier reply post here. Take a look at it. I've done the same thing for 26 years. Have never had mold or algae in the system, have always had good tasting water in the trailer and have never had anyone get sick when camping. Everyone has a different answer. BUT...its not rocket science. Its hygene. Good travels.
Old 03-24-2020, 08:46 AM   #17
Wolverine 1945's Avatar
Originally Posted by Mike223 View Post
Ditto for me also.
Mike
X-3 !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-24-2020, 08:56 AM   #18
Those manual are usually 'generic' and not specific to your rig. So you have to do what works best for your rig.
My best guess would be that they want you to added diluted bleach to the tank to avoid potential problems with any seals on the rig or adding to an empty tank (or undiluted bleach on your hands.)
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 03-24-2020, 09:37 AM   #19
NJKris's Avatar
Don't forget to sanitize your hoses too. I pour some dilute bleach into the end of he hose after I hook it up to RV city water connection, then connect to water supply and turn water on briefly so hose fills up, let it sit that way for a spell.
Old 03-24-2020, 11:44 AM   #20
I know this one will fall on deaf ears because I can't find anything below $65, but the ONLY way is to have a DPD free chlorine test kit. You test for 0.5 ppm give or take, and you can drink the water. Otherwise, you don't know for sure what you really have. Water can go bad in two hours, or be good for two years. There is no substitute for scientific data.
SageCrispin is offline   Reply With Quote
tank, water
