Originally Posted by miguelregis
Question regarding my new 2018 Oasis 18BH Travel Trailer.
How long should it take to fill a 46 gallon fresh water tank and water heater?
I am unable to get my water pump to pump water thru the pipes to the kitchen and bathroom tub faucets.
Unsure if the water levers are position correctly?
Attachment 175600
Most all the water lines and tanks are pretty much like this first attached pic. This configuration shows the system in winter bypass mode. Note the direction of the valves. The middle vertical line or "bypass" line, the valve is horizontal to the water line, allowing water flow through. Note the top red (hot water) and blue (cold water) line valves are vertical to the lines. Blocking water from going into the hot water tank in the back. Simply reverse the three valves for summer, normal, usage.
The second pic is similar to what your water pump may look like. Note that the single valve here is running horizontal to the water line coming out of the pump. This position allows flow, or is considered ON. Without this valve ON, you will get no water pumped to the trailer via the pump. Hope this helps.
Get in there and follow the lines, look at the valves again, and check their direction.
