How to drain fresh water in a Forester 2018 3271S
I have a new Class C Forester 3271S. I want to drain the freshwater tank so I can sanitize it. How do I do I drain the tank?
There are two pipes below where I think the water tank is. One is blue without an end cap. The other is rea\d with a cap on the end.
Also, behind the panel that covers the water pump, there are several valves. There are no labels for the valves. I know one combination of the valve settings are so you can suck up the winterizing fluid when it is time to winterize. I am not sure if a certail combination of the valves will drain the water tank.
Any help would be apreciatated.
Thanks in advance.
