Old 07-10-2017, 10:27 PM   #41
cardwellmarty's Avatar
It's a Suburban Sw6DE
cardwellmarty is offline   Reply With Quote
Old 07-10-2017, 10:32 PM   #42
I looked at the plug to see if it had rusted off, but it is just a plug, I took a stiff piece of wire and felt nothing in the bottom of the tank but some silt. The model plate with numbers etc. is still on the water heater, my TT is a 2007 if that makes a difference.
Old 07-10-2017, 10:42 PM   #43
Has the Anode rod deteriorated, if so it is completely gone?
Old 07-11-2017, 05:37 AM   #44
007matman's Avatar
That would be my bet. They should have a copper wire from what I understand at the core but that doesn't mean someone could'nt have cut it off.
You could try taking a photo. That night help. I've only had mine out a couple of dozen times recently.
They are around $13 on Amazon. I just bought a new one to have as a spare.
Suburban 232767 Water Heater Anode Rod https://www.amazon.com/dp/B003VAYRNM..._XRkzzbTDDE1S5
007matman is offline   Reply With Quote
Old 07-11-2017, 06:29 AM   #45
Mr. Dan's Avatar
Originally Posted by Mr. Dan View Post
No anode rod means you probably have an Atwood water heater. Suburbans have 'em; Atwoods don't.
Sorry. I misinterpreted "no anode rod". I thought you meant "didn't come with one ".
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 07-11-2017, 09:05 AM   #46
Drained the water heater, I don't think it had been off since it was new, there was no Anode Rod, I took a stiff piece of wire that I put a hook in and cleaned sediment out as I drained the tank, it wasn't as bad as I would have thought. Should an Anode Rod be put in, I understand there purpose or are they all that?
The answer is "yes." The anode rod does the "rusting" instead of the tank.
(Suburbans have steel tanks that rust. Atwood's have an aluminum tank that doesn't rust, that's why Atwood's don't have an anode rod.)
2011 Traverse LT, 3.6L, FWD
Old 07-11-2017, 09:28 AM   #47
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
Hey Now, a couple easy / obvious ways for those who don't have a FW Drain available ...
  • Use the outside shower or hose attach and pump it out
  • Attach hose with a Water Bandit (Thief) to kitchen or bath faucet, and again pump it out that way.
Not the fastest, but would work.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 07-11-2017, 10:05 AM   #48
This won't drain the heater, which was what the OP was trying to do. Also, it will drain the FW tank (mostly) but won't drain the lines themselves; you'd need to blow them out with compressed air.
Old 07-12-2017, 09:42 AM   #49
You are correct ... thought there was a question about it taking "forever" to drain, wonder if that was in a different post about draining fresh water tank.
Water Heater would of course be a matter of RTFM'ing.
Jeff and Abby
Old 07-13-2017, 07:21 AM   #50
Wolverine 1945's Avatar
Be careful of that Pic O Crap White FW drain valve,,, they break very easily !!!
Then you get to drill out the rivets,,, and screw a new one in !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-13-2017, 08:43 AM   #51
Thanks Wolverine.
Old 07-13-2017, 09:30 AM   #52
Thanks Wolverine.
Your Welcome,,, I learned that the Hard way !!!
drain, fresh water, tank, water, water tank
