I've seen numerous offerings of water tanks, Fresh or Black and Gray, online.
Check the numerous sources and use the dimensions you have to select one.
Most Black tanks are supported by the top configuration of the tank, hanging on pieces of angle iron running from frame rail to frame rail. Make sure the tank has these steps on it and dimensions match so tank is properly supported.
Just an observation, even if the dump valve was closed the pressure in the tank should have been relieved by the roof vent. Hard to see how a 1-1/2 " vent stack could restrict air and subsequently water flow caused by a 3/4" hose pushing water into the tank.
Sounds like the vent was plugged and naturally should be addressed when installing the new tank.
FWIW, I wouldn't worry about getting an "exact" replacement. A good repair person should be able to install any top mounted tank that fits the space and hangar rails. Holes for vent, toilet dump, and flush, usually have to be installed when mated with a specific setup.
