Old 05-15-2017, 09:38 PM   #1
How to manually check black/gray tank levels?
I've got a 2017 Rockwood Mini Lite 2014S.
A consistent comment on this and other forums about tank level indicators is they are notoriously unreliable. So....how does one check the tank level if not sure about the 1/3-2/3-Full indication? An idea for the black water tank seems simple but a bit gnarly...with fresh water depressurized, step on the flush lever to open the flapper and use a stick of some sort to measure tank level. But there's not a direct path into the gray water tank. Ideas? Thanks!
jackconn is offline   Reply With Quote
Old 05-15-2017, 09:45 PM   #2
RandK-M's Avatar
If your toilet is right above the tank, a flashlight is all you need. Gray tanks are usually pretty accurate.
On a side note, I installed Hurst Miracle Probe sensors and most of the time they work fine. Sometimes immediately after dumping, the black tank doesn't read empty, but after a few minutes it clears. When I use the black tank flush, they always read perfectly after dumping.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is online now   Reply With Quote
black, check, manual, tank
