07-02-2021, 08:30 PM
Huge tank support problem! Need help please!
Ok, I just happened to look under my trailer and saw what is in the picture! This is a brand new trailer out for the fourth time now and hooked up to water and electrical at the moment. What is it and how do I fix it?
I have a forest river 178BHSKX
07-02-2021, 08:32 PM
I would guess it's your fresh water tank that has broken its supports.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
07-02-2021, 08:35 PM
You may need to undo the cover and see if you tank bracket has broke or come loose. If you are handy you may be able to fix it. It looks like your fresh water tank has fallen. Good Luck.
07-02-2021, 08:38 PM
not unusual... many reports of tank support failures... good thing it did not fall out on the highway...
2014 Shamrock 183
07-02-2021, 09:17 PM
You said it's new, ... it's under warranty, drain the water to get rid of the weight and then take it to your dealer or call mobile service, FR should take care of that, ...
07-02-2021, 09:27 PM
It happens many , many times > Dealer will take weeks or months to fix . You can do it yourself in several hours and a trip to Tractor Supply or Home Depot . By some quarter by two strap or something that you like . That is the first alteration that I make .
07-03-2021, 08:33 AM
Holy Horrors
I agree with all that's been said. What I would like to see is a better picture of your frame. In the picture you posted it looks to me like there is frame damage at the right hand edge of the picture OR it is just the way the light is hitting it. I'm thinking possibly the when the water tank let go it twisted the frame member with it. I would really like to be wrong.
Paul
Paul / Carole Ann and 'Monte' the Goldendoodle
2023 Rockwood Ultra Lite 2608BS
2020 Rockwood Mini Lite 2511S
2017 Rockwood Mini Lite 2502KS
2012 Ram 2500 6.7L Diesel
07-03-2021, 08:44 AM
You say you are hooked up to water at your site. Does the sagging tank have water in it? If so I would look to see if you have your water hooked up to the city water inlet on your rig or is it hooked up to your tank fill connection. Also you might want to search the forum for "city water filling fresh water tank".
2020 Coachmen Clipper Cadet 17CFQ
2014 F150 Lariat Super Crew 5.0
1954 Wife
07-03-2021, 09:27 AM
07-03-2021, 09:55 AM
Kind of wondering if hose is hooked up to fresh water fill and tank has expanded from pressure. Should have an overflow valve but maybe not.
I have seen a tank expand from overpressure (no pressure regulator) and they can get really big.
2017 FR3 28 DS
07-03-2021, 10:06 AM
tank epansion ? extra air comes out of filler opening Via vent or fill opening. I put c channel across my frame to keep tank up. drill and bolt .
07-03-2021, 10:24 AM
You should get it fixed under warranty, but you'll be out of service for weeks, if not months, IMHO. I agree with other posters that you should be able to fix it with some angle iron and bolts.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
07-03-2021, 11:25 AM
Like others, it looks like the fresh water tank either had poor supports or the Mfg. forgot them, completely, no surprise either way though you might want to check the gray and black water tanks. Best to let the dealer do this but that could take a long time. Unfortunately we read about this a lot and I, too had problems like this on a new TT back in 2003 we bought. Being handy it was easier for me to permanently fix the problem than bring it back to the dealer. Did you fill the fresh water tank up before you left? Coupled with poor roads can be a disaster for poorly secured full tanks. It was also mentioned if you attached the city water to the fresh water inlet instead of the spot for city water then turned it on... could be but it should have an overflow on it unlike gray and black water tanks. No matter what, when you or the dealer secure this make sure any venting or other plumbing attached is checked out since this could've had an impact on them, too. Wish you luck, sorry for your troubles and let us know how you make out please...
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (6 y/o)
Stephanie (daughter)/Rick/Callie (14 y/o)
Great Granddaughter - Cora (2 y/o)
Great Grandson - Zek (1 y/o)
Phillip (son)/Charlotte (6 y/o)
07-04-2021, 05:31 PM
We have a 2021 Coachmen Spirit 1943 RB, the fresh water tank is 49 gallons.
Last trip was a 4 night dry camping site so we started with a full fresh water tank. I noticed both supports under the underbelly enclosure was bowed in the middle a good inch or more. The ends of each are simply fastened to the frame I Beams with two Tek screws on each end so it all is a future fail point in my opinion.
Attached is a photo of one of the two channel cross pieces. My plan is to get a beefier steel support, then will simply put it next to each one. I’ll be relying on what a local steel shop recommends, have them cut to the outside dimension of the flange of the I Beam, then bolt them onto the outside flange with lock nuts and locktight. Yes, I could@ have warranty deal with it but it’s not worth driving to the dealer 80 miles away.
07-15-2021, 06:24 PM
The supports are usually underneath the bottom cover.
07-15-2021, 07:22 PM
Use square tubing. Much stronger than the U channel. Also add a few more spaced evenly under the tank.
07-16-2021, 06:40 AM
that's y I don't carry water .the trailer is made light weight so they use the thin medal to keep the weight down . so if u have a 30 gal tank the weight u r carry 240 lbs and that water is moving around and bouncing on the straps.I been camping over forty yrs.never carry water.I have a couple gal of water if needed
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
07-16-2021, 12:35 PM
Sad to say but it is a common occuarance. Mine happened 6 months after we purchased the trailer and had two local trips with it, yes it was full but it should be made to handle that.....notice I didn't say engineered!
I almost took it back to the dealer but then realized that their repair will be to "restore to new"...well new didn't work the first time, so....No.
I added 1/4" steel angle iron along both long sides and used the same across as braces.
it's been 2 years and many local and a few long trips and no issues, yes while full.
Another thing to remember, if a tank swell down it may have also swollen up. Check the floor area above the tank.
'18 Rockwood ROO 21SS
600# Fastway E2 WDH
'14 F-150 FX4 SuperCab
07-16-2021, 01:15 PM
Subscribing......
Brother Les
