05-04-2018, 02:02 AM
I can't believe I...
First trip for the year. Figured I would dewinterize at the campground. Fill my water tank with water at site, asked my wife to start turning on faucets to get the water running. She's telling me no water is coming out, but I hear the pump running.
I forgot I disconnected the waterline to the pump and took off the pump screen. No issue, a little water in the pass through. Connected everything up, turned on the pump. I could hear water running and then my wife yelling to turn off the water! I ran inside to turn the pump off and she is in our bedroom. There are no water faucets in our bedroom?
Oh me, the washer lines! I left them open over winter to make sure all of the water drained out.
Not too big of a problem, maybe a gallon or two of water in the closet. Good thing we live in Denver, it was bone dry in a couple of hours. I hope they used marine grade plywood like they said they did.
I guess I need to add "close washer lines" to my checklist. Or just close them after I blow out all my water lines.
Live and learn.
05-04-2018, 06:26 AM
I have a habit even during camping season that before I turn on the water I check to make sure the faucets are all off, call me paranoid!!!!
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
05-04-2018, 10:59 AM
Always Learning
Is it wrong that I'm chuckling? I can totally see me doing both of these!
05-04-2018, 11:02 AM
I would not disconnect any water lines to winterize. You should be able to do a good job with everything connected.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-04-2018, 11:10 AM
I missed something.....
what's 'different' in Denver?
05-04-2018, 11:17 AM
Washing machines are notorious for difficulty in winterizing. You can, however, pump antifreeze through them and make sure the pump sees enough antifreeze to force out all the water.
wish my cottage had a water pump and antifreeze intake, but then there is a lot of waterline to fill.
2015 335DS
05-04-2018, 11:24 AM
I had left the kitchen faucet open and when I hooked up to city water, of course it started to flow - right on top of the cover over the sink. Made a nice little mess
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
05-04-2018, 11:41 AM
Denver is very dry, as in not humid, so things dry out faster than in places like Florida.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
05-04-2018, 11:57 AM
Yep.... a lot of 'dry' snow in Denver....
Brother Les
05-04-2018, 12:27 PM
Thank you for posting - I thought I was the only one to make mistakes. “Oops” came from our Pop up when I cranked the emergency brake cable up into the mechanism and didn’t notice it. Pulled it home that way too. But at least I learned how to replace brake assemblies and bearings lol DW just grinned...
05-04-2018, 12:57 PM
That is how I found out I had a busted line under the kitchen sink after the winter months, I was standing out side and couldn't figure out why I had water running out of the camper wall, then it dawned on me, I have a problem. The DW will sometimes say I am a little slow.
05-04-2018, 12:58 PM
Thanks for sharing your opps! Just added to our dewinterizing checklist to check the washer faucets. My wife can't remember if she closed them or not after winteriation.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
05-04-2018, 01:56 PM
Old Engineer
Winterizing Washer
Pour about 1/2 to 1 quart of RV antifreeze into tub. Run short spin/drain cycle to fill pump.
Should be good to go.
I have a washer in a place that gets down to -30 F in the winter.
Haven't had a problem yet.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
05-04-2018, 02:20 PM
Even though we do get snow in Denver, not much this year, it is a high altitude desert. It is typically 40-50% humidity.
Thanks for the info about winterizing the washer, we don't have one, yet. I also don't use antifreeze to winteri
ze my water lines, I just blow them out and leave all of the drain lines open. I think next time I will close them after a couple of days draining and drying.
05-04-2018, 02:27 PM
Before we had a washer I used to winterize from the washer hookups back seeing they were the highest point everything blew down and I kept the low point drains open, I would close them to do each faucet also.
2001 Kenworth T2000
05-04-2018, 02:34 PM
Curiouser and Curiouser
There are so many ways to do things wrong on an RV. Glad to see you have entered the competition!
Finch
2016 FR3 30DS
05-04-2018, 02:50 PM
Maybe the forum needs a RV Darwin Awards section?
05-04-2018, 03:19 PM
Retired Navy
Looks like the plan to dewinterize at the camp ground does not allow a sanitation step for the fresh water system...
2012 Lexington C Class
Toad: 2009 Honda Fit
05-04-2018, 03:27 PM
Old Engineer
OK, how did you know my middle name was Darwin?
05-04-2018, 03:49 PM
My DW says God gave me the gift of being able to fix things because I break so much stuff
I say he gave me the gift of my father....who taught me how!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
