10-14-2019, 12:03 PM
I May Be a Newbie But This is Wrong...
While winterizing our 4 month old 2020 Rockwood 2506s this is the condition of the Rod from the Water Heater. How can this degrade so quickly with only a total of 12 days of use?
10-14-2019, 12:05 PM
Did you drain the water heater after each trip, it has it had water in the tank for four months
2011 Flagstaff 831 RLBSS
10-14-2019, 12:11 PM
Practically brand new. I'll take it from ya.
10-14-2019, 12:41 PM
Anode rod condition has more to do with the quality of water than the time used.
10-14-2019, 03:18 PM
Doesn't look that much worse than the one from my 2020 TT. Filled the water heater probably around June, and never emptied it until last week. My previous TT did not have an anode rod, so I wasn't sure what to expect. From what I understand they're inexpensive, and obviously easy to replace. And so far I've had no "rotten egg" water, like I would get on my old TT.
I guess it's a small price to pay.
2020 Cherokee Grey Wolf 18MT
TV: 2014 RAM 1500 5.7 Hemi
10-14-2019, 03:22 PM
Part-Time Campground Host
Looks good to me, you'll get another year outta that one.
Craig & Cath
Days camped since 2015(retirement): 1689
10-14-2019, 03:29 PM
That actually looks pretty good for 4 months.
This is mine after a full season of use:
10-14-2019, 03:35 PM
Actually looks pretty good depending on the condition of the water it was exposed to. Some water sources will degrade the anode rod more than other sources depending on the mineral concentration of the water.
2014 Prime Time Sanibel 3250
10-14-2019, 03:52 PM
The consumption of the anode rod is dependent on the quality of the water in the WH and how long it is there. If using well water drain it after each use. Not only does it prolong the life of the anode, but it reduces the amount of crud in the bottom of the tank that can eventually work its way into a faucet screen or valve and clog it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
10-14-2019, 04:04 PM
How does well water affect the decay of the anode rod? I would think the more minerals the faster the decay? Perhaps not?
Our well has been tested and the person testing it says he has never seen such a "soft" water reading before.
Is "soft" good or bad for a water heater anode?
RBDTx
2020 Rockwood Mini Lite 2109s
2019 Toyota Tundra TRD Pro
10-14-2019, 04:09 PM
Broken Toe
The anode rod is sacrificial... meaning that it is designed (and supposed) to corrode, to keep other (read: More expensive) parts from corroding instead. Corrosion is not an indication of any failure, but is an indication that it is doing its job.
I would be much more upset to see one with no corrosion.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
10-14-2019, 04:37 PM
Ill bet nobody ever checks the anode rod in their home water heater. Yep it has a rod just like your RV.
10-14-2019, 06:36 PM
I thank you all for the education today!
We owned a large Regal Cabin Cruiser for many years and never looked at the Anode Rod in the Water Heater, unlike the sacrificial Zinc's mounted to the out-drives which were changed out.
Is it advisable to drain water heater after each trip? Is there additional steps to take as well to improve longevity?
Thank you again!
Tim
10-14-2019, 07:01 PM
I'm a newbie as well and I was wondering if all campers have this? I can't find one. Only plug I have is to drain tank. Just a plastic plug with nothing on it. What's the deal? The camper is a 2011 Coachman Freedom Express
10-14-2019, 07:06 PM
Thank you again!
Tim
they are so inexpensive, that i would not worry about improving longevity. and they last quite awhile - my current rod has lasted 3 seasons so far.
and about draining the water heater after each trip - up to you. we do not drain ours during the camping season but we are out every 2 weeks or so - so it gets plenty of turn over. if we were not to go out for a month or so, i would empty it.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
10-14-2019, 07:09 PM
Forest River uses different brands and types of water heaters. The Suburban tank type water heater has an anode rod to protect the steel tank.....whereas an Atwood/Dometic brand tank type water heater with an aluminum tank does not need an anode.
If you have an aluminum tank, then your RV doesn't use an anode.
10-14-2019, 07:10 PM
depends on the model of water heater you have. The Atwood water heaters do not need/have an anode rod, the Suburbans do.
10-15-2019, 04:10 AM
Ah Ok thanks for that's!! It's a aluminum tank. I do know that much so that explains it!
10-15-2019, 12:52 PM
Thank you again!
Tim
That's entirely up to you. You'll get all sorts of responses to this question. Our camping season is all of 4 months. I only drain the water heater when I winterize. How fast the anode rod deteriorates depends on the quality of the water you're using. I can get 3 camping seasons out of a single rod. They're not that expensive, $10 at Walmart. Just remember to flush/rinse out your water heater when you pull the rod out for winterization.
2016 Salem 27RKSS
10-15-2019, 01:17 PM
This is my anode after 5 seasons. I'd say it's only about 30-35% used. I only drain the WH at the end of the season. As others said, it's related more to the quality of the water it sees than how old it is.
2011 Traverse LT, 3.6L, FWD
