Old 09-14-2021, 11:21 PM   #1
I need water filter for my kitchen sink
Something that will fit a stock Sonic X 211vdbx faucet.
The well I'm using tastes like trash.
chovyfu is offline   Reply With Quote
Old 09-15-2021, 12:03 AM   #2
Why not put in a ”whole house” water filter at the outlet of the water pump downstream of the city water inlet tee. Both city water and water from the fresh water tank will be filtered. Standard activated charcoal canister. Then if you want extra filtration use a Brita filter pitcher.
NavyLCDR is offline   Reply With Quote
Old 09-15-2021, 12:09 AM   #3
I already filled the tank so it tastes terrible out of the sink. I could get a pitcher but not sure if it’ll fit in my fridge.
Old 09-15-2021, 05:34 AM   #4
[/QUOTE]https://www.target.com/p/brita-water...B&gclsrc=aw.ds
We use this small Brita in our Dometic fridge. I believe it fits in the bottom door shelf.
2018 E450 Forester 2291S
Sergiop is offline   Reply With Quote
Old 09-15-2021, 06:33 AM   #5
Chuck_S's Avatar
Even my Roo hybrid has a full system water filter using common household in-line water filters from Lowes or Home Depot. If the source water is suspect I run it thru a hose filter when filling the fresh water tank -- and filter it again when it comer out via the full system filter. Ain't rocket science nor special "RV" stuff.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 09-15-2021, 09:56 AM   #6
What do you use at home?
sink, water, water filter
