Old 04-05-2017, 06:01 PM   #1
Ice maker?
Have a 2014 36ckts and was wondering how to get ice maker to work? Is there a valve I need to turn on?
pavetim is offline   Reply With Quote
Old 04-05-2017, 06:46 PM   #2
Stevemc's Avatar
On our 2013 36ckts there is a push/pull type valve under the slide. We don't use the icemaker so I've never turned ours on.
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 04-06-2017, 08:23 AM   #3
njfishing's Avatar
Not sure how your ice maker is set up but 2 simple things to check... One, is it getting water? If you have water at the sink but not to the ice maker, you may have an inline shut off valve somewhere that needs to be opened. Two, there is thin metal arm on most ice makers. When there is not enough ice in the ice tray the arm drops and triggers the ice maker to make more ice... Be sure there isn't anything restricting that arm from coming down. It should move freely both up and down.
Hope this helps.
njfishing is offline   Reply With Quote
Old 04-06-2017, 08:29 AM   #4
BandJCarm's Avatar
What they said ^^^^^^........
Dang valve is hard to get to......reasons unknown. It's on my list of "Custom Changes Needing To Be Made" someday......if possible. It took me long time to find it originally. On the wire arm, it is unlike our old home refrigerator's arm in a way......it is more 'firm' in it's closed position. You have to push it pretty hard to get it up (closed) or down (functional). I was afraid I'd break it at first. FYI.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 04-06-2017, 08:35 AM   #5
AquaMan's Avatar
Depending on model of fridge (residential), it may also have an on/off selector on the menu.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-06-2017, 08:38 AM   #6
I guess this happens when you put a reefer on a slide. 1/4 feed line is flexible, but not predictably. However, I don't see why the valve can't be closer to the solenoid on the back of the reefer rather than under the slide.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-06-2017, 10:27 AM   #7
Stevemc's Avatar
It is inconvenient. Ours is not too difficult to reach when the slide is out. I suppose once you turn the valve on to make the ice maker operational there would be no reason to turn it off again so it would just be a one time thing. All it does is open the waterline to allow water to get to the ice maker.
Steve & Jean
Furbaby - T.J. RIP
Old 04-07-2017, 07:29 PM   #8
I looked under the slide and didn't see any valve. I am asssuming right under where the fridge sits?
Old 04-07-2017, 09:19 PM   #9
Stevemc's Avatar
I think ours is farther back over the wheels. Just going from memory I'll have to look at it and try to get a picture but it'll be a couple of days before I get a chance.
Steve & Jean
Furbaby - T.J. RIP
Old 04-10-2017, 09:53 AM   #10
Stevemc's Avatar
Ours is farther back than I remembered. It is about 18" behind the rear jack. It's a white plastic push/pull type valve. The waterline for the icemaker runs from there under the slide to the fridge. Sorry I can't add a picture. When I click on the paperclip it only gives me options to edit the photo.
Steve & Jean
Furbaby - T.J. RIP
Old 04-10-2017, 10:07 AM   #11
Not sure what platform you are using (mobile app or PC) but if on PC and you click on the paperclip there should be another pop-up box open where you can upload photos.
On the mobile app, when you click on the paperclip it should open your photo gallery where you can select a photo.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 04-10-2017, 10:47 AM   #12
Stevemc's Avatar
I'm using the mobile app on an android Samsung phone. When I click on the paperclip it opens my gallery, when I select the photo I get a choice of several editing options across the bottom but no choice to insert the photo. Thanks
Steve & Jean
Furbaby - T.J. RIP
