10-30-2020, 08:56 AM
Is my water heater gas only?
I have a 2011 Georgetown 378ts. I'm not near the MH right now so can't really look at anything, but when I was working on it last week, I didn't see any wiring that I could identify as 120V to the water heater. Did this thing come with only lp? I also didn't see a switch.
2011 Georgetown 378TS
CQ de K4GVO
10-30-2020, 09:33 AM
you are going to need the model of the water heater in order to get any meaningful answers.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
10-30-2020, 10:28 AM
Just as confused as you
Until you get us the model of your water heater you can look in the breaker panel for a breaker for the WH. The 120vac electrical connection will be behind the water heaters tank body, likely in a position you will not be able to see easily. If you have a Suburban water heater, open the panel on the outside of the motorhome and look on the lower left side for a small rocker switch. See the photo attached.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
10-30-2020, 10:42 AM
All the wiring is behind the water heater if you have a tank type heater. If you have a tankless/on demand water heater then it probably is gas only.
A picture of the water heater will let us easily identify it for you.
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
10-31-2020, 10:00 AM
Alot of rv hot water heaters are just propane. If you don't see a 120 wire going to it, probably propane only.
10-31-2020, 10:46 AM
The brochure I found online for the 2011 Georgetowns states this in the specifications:
“ • 6 Gal. G/E DSI Water Heaters”
Unless your water heater has been changed-out to propane-only since it was built, your water heater is gas and electric.
Bruce
10-31-2020, 10:55 AM
2012 Georgetown 378TS is 10 gallon Suburban LP/electric water heater. 2011 GT 378TS is the same.
11-02-2020, 06:58 AM
Thanks everyone. When I get back in town, I'll take a closer look and report back. The unit looks pretty old so I'm guessing it's the original.Also I need to pull the anode out and see what shape it's in. There is a spare anode laying by the WH.
Jim.
CQ de K4GVO
11-06-2020, 07:19 PM
And it has a very hidden switch. I did't see it, but it's there. Thanks everyone.
Jim
CQ de K4GVO
11-07-2020, 10:45 PM
Don't use that water heater on the electric setting unless it's full of water (turn on a hot water faucet to fill). ... but you probably already knew that.
2015 Dynamax REV 24TB class C
11-08-2020, 01:51 PM
It's had water in it since I bought it. When i finally located the switch it was ON. The water was not hot, so I checked the breaker inside. It was off, so I turned it on and I'll see what happens. The WH is full of water, I was able to get water to come out of the relief valve.
Thanks,
Jim.
CQ de K4GVO
11-08-2020, 01:57 PM
Thanks,
Jim.
So your saying you've had water in the heater since you got it ? what kind of used to you get out of it ? if it's been sitting long you could have some nasty water in there . for sure pull the anode and see what comes out .
11-08-2020, 04:09 PM
We just bought it. I've run water through the system a couple of times in the past 6 weeks or so. We camped in a couple of places so the water heater has been purged. It just won't heat with electricity. I heats up fine with gas. I plan on pulling the anode, I didn't have a 1 1/16 socket and ordered one. It came today. I'll probably pull it tomorrow.
I reset the breaker and checked, it's not heating. I'm guessing someone before me turned it on empty. The fellow that had it didn't seem to know much and I think had only had it for 18 months or so. For instance, he insisted it had an inverter which after inspecting the rig I knew was not true. There were other systems he didn't know anything about too. So at this point I don't have electric hot water nor do I have a working front furnace. I hope to fix one of those issues in the very near future.
Thanks,
Jim.
CQ de K4GVO
11-08-2020, 04:35 PM
I and other had the little power switch go bad on the heater itself.
It can be poopped out to check to see if you have a hot coming from the circuit breaker.
By All
No longer a member here.
Dec 12, 2020
11-08-2020, 07:58 PM
So it's a press in switch? Thanks, I'll give that a try. Don't worry I'm very familiar with A/C trouble shooting. I won't electrocute myself but I am surprised that it would be that easy to access.
Thanks,
Jim.
CQ de K4GVO
11-08-2020, 08:27 PM
Thanks,
Jim.
Jim it has spade connectors and installed a plastic fuse until I found a replacement and used the inside CB to control the water heater.
Iggy
By All
Dec 12, 2020
11-09-2020, 08:21 AM
Iggy
As usual, very valuable information. Thanks.
Jim.
CQ de K4GVO
11-09-2020, 08:47 AM
Iggy
What sort of plastic fuse did you use on this 110vAC line?
I just jumpered the two black wires and used the inside CB until I drove 4 miles and bought and installed a new switch before I moved the trailer from my site.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Thanks,
Jim.
You can verify voltage at the element . that little toggle switch is a weak link . i removed mine and installed a lighted switch inside . Elements are cheap around 14$ 1440 watt easy peasy .
11-09-2020, 08:51 AM
Kanadian Kamper
Jim.
Jim......
Iggy is your “go to guy” like no other.
He also owns a 378 model (at least so far  ) and Iggy has more photos than anyone I know.
Just sayin’
Ken and Terry
2018 Sunseeker 2430S
and might rarely get pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
