Old 11-28-2020, 02:40 PM   #1
Kinked Fresh Water Hose, 18RJBBL
Hi, all, from a noob, both to the forum and to travel trailers.
I bought my 18RJBBL two months ago and all has been well so far, including four camping trips. I winterized yesterday without any complication, but as I accessed the basement plumbing I noticed that the fresh water hose from the tank to the pump was kinked (see pics). So far I've used only city water so I don't know how this will affect flow. But my hunch is that it will be considerably restricted, especially when suction from the pump is applied.
I bought the RV from an out of state dealer (I couldn't find this model in Virginia at the time), rolling the dice on warranty issues. I'm certainly not going to drive 180 miles just to have this fixed, and I'm open to attempting a DIY job. (With physical limitations: My inflexible, 63 year-old, 260 pound, 6'4" body with mild chronic back and knee issues makes it a challenge to work in confined spaces.)
So my questions: How do I best resolve this now, and how do I prevent it in the future? I'm guessing the best thing is to replace the hose, given that the kink has almost certainly been there for several months and has likely developed some degree of permanence. Can I do that from the basement by removing and later replacing the sealant goop (I assume that's its purpose) where the water lines pass through the flooring? Any pitfalls to be aware of with that? Or do I need access from beneath the trailer (I haven't looked there yet)?
Then for prevention, I figure a longer hose might be the simplest thing, allowing for a larger coil or coils for the hose as it makes its way to the pump. I thought about raising the pump a few inches off the floor via a piece or two of 2x4, allowing a wider turning radius for the hose. But I don't think I could get to the pump for this without removing the panel above it, requiring removal of several adjacent components (like the strut for the bunk bottom shown in pic #3). I'd rather avoid all that, especially given the above-mentioned physical constraints.
Thanks in advance!
Jim
Name:	Fresh Water Hose #1.jpg
ID:	243769   Click image for larger version
Name:	Fresh Water Hose #2.jpg
ID:	243770   Click image for larger version
Name:	Fresh Water Hose #3.jpg
Jimbo K. is offline   Reply With Quote
Old 11-28-2020, 02:46 PM   #2
Funengineer's Avatar
Would something like this work?
https://www.lowes.com/pd/HoldRite-2-...ort/1000382087
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is offline   Reply With Quote
Old 11-28-2020, 04:16 PM   #3
bikendan's Avatar
You must not know that, if you're still under warranty, you can use a different dealer, an independent RV shop or a mobile RV tech. You just have to get pre-approval from FR and be willing to be reimbursed. You might not be able to get a closer dealer to do the warranty, since you didn't buy from them, especially during these busy times.
Old 11-28-2020, 04:29 PM   #4
Trailer Park Supervisor
NJKris's Avatar
My black tank flush hose was like that, they didn't allow enough hose to make the bend and it kinked. I caught in during PDI. They put a couple worm gear hose clamp on the kink, and it remains fine. So see if you can unbend kink, maybe squeeze it with pliers and put a couple of those clamps on for now.
Another quality Forest River job.
NJKris is online now   Reply With Quote
Old 11-28-2020, 04:33 PM   #5
Thanks in advance!
Jim
I would just cut it and install a brass 90 . easy peasy and won't kink again
MR.M is offline   Reply With Quote
Old 11-28-2020, 04:36 PM   #6
Mr. Dan's Avatar
I haven't had this issue with an onboard hose (yet)... but when I have this issue with any water hose, I wrap a length (12" maybe) of left-over 12awg house wire (Romex) around the kink while holding the kink in a smooth bend. When I'm done, it looks like I've placed a spring around the kink. It's cheap; I'm cheap.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 11-28-2020, 04:56 PM   #7
The 90 sounds easiest and fastest. Less time spent in a contorted position.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 11-28-2020, 05:45 PM   #8
Tapex's Avatar
Here's a that suggested 90į bendClick image for larger version
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is offline   Reply With Quote
Old 11-28-2020, 06:50 PM   #9
I think that's fiber-reinforced vinyl hose, not PEX. If so, the Shark-bite won't work. An internal elbow with an Oetinger clamp would.
Old 11-28-2020, 07:01 PM   #10
Originally Posted by Funengineer View Post
Our E-Pro has a couple of these to prevent kinks.
tempestdriver is offline   Reply With Quote
Old 11-29-2020, 02:50 PM   #11
Use hair dryer and re form the hose or get some fittings and some more hose and loop it more
locogk is offline   Reply With Quote
Old 11-29-2020, 06:00 PM   #12
I have successfully used a 90 degree nylon elbow with hose barb ends and a couple of hose clamps. Worked fine. Just cut the existing hose at the kink and put in the barbs and tighten the clamps. Elbows are at Home Depot, Lowe's, or Menard's. They should be around a couple dollars. Just get the elbow for the ID of your hose and hose clamps to fit. Quick fix and it will take the bend out of the hose. then you won't have to worry about taking the hose out of the foam sealer or disturb the clamps on the other end of the hose.
ProfChuck is offline   Reply With Quote
Old 11-29-2020, 06:51 PM   #13
Tapex's Avatar
Great to hear you got it fixed, and thanks for your follow-up!
Old 11-29-2020, 07:50 PM   #14
Mr. Dan's Avatar
Actually, this is not the OP. This member just posted what he had done back in the day.
Old 11-29-2020, 09:05 PM   #15
I'm thinking this or some variant of it might be the best approach. Thanks!
And thanks to all who offered ideas. Regardless of what I do, it likely will not be until springtime. I want to run water through it and check for proper function and leaks before closing that compartment off again. Plenty of time to think on it and plan my approach.
Jim
Old 11-29-2020, 09:07 PM   #16
Yeah, I'm a little underwhelmed with the workmanship on this thing.
Jim
Old 11-29-2020, 09:09 PM   #17
Thanks for considering my need to avoid contortions!
Old 11-29-2020, 09:16 PM   #18
Yes, I knew that, though thanks anyway. I suppose I could have mentioned originally that I would just as soon avoid dealers or even a mobile tech completely if I can make the repair easily and inexpensively. I'm not strongly mechanically inclined, but I'm adventurous enough to try a DIY job if I have the knowledge (or can gain it), physical ability, and tools, irrespective of the warranty.
Jim
Old 11-29-2020, 09:17 PM   #19
Old 11-29-2020, 09:56 PM   #20
Tapex's Avatar
Thanks Mr. Dan Just thumbing to darn fast and then, well you know...over looked reading
fresh water, water
