Originally Posted by Wildbill57
Good morning all. Arrived at campground yesterday after traveling on some very rough roads to find my kitchen sink just hanging down from the counter. Is the only thing securing it to the counter some sort of silicone. I don't see any type of clips underneath at all 2019 Rockwood 2509S
Mine wasn't that bad and it had a few clips. We started seeing water on the stuff below the kitchen sink. I could slip a paper towel in the gap between the top and bottom.
When it went back to the factory for work the dealer could not handle I wrote the two sinks up (kitchen and one bathroom) and requested that some bracing be installed.
They just applied caulking, no bracing, and did a really sloppy job to boot. Caulk was smeared over the top edge on one sink and I had to scrape some small clumps of hardened silicone out of the sink bowl.
To boot, both bathroom hot faucets squeak and bind when the hot water hits them. I wrote those up as well. The alleged tech wrote that they lubed the valves, which are not designed to be lubed. And no change upon its return, of course.
We're out of warranty so now the problems are mine.
Ray
