Originally Posted by rushhohol
When I bought my Sunseeker the water in the kitchen sink was running well. Now it's get running just little bit. I cleaned filter, but it's still running little bit. Without the filter running big stream, but with filter little.
Is that should be like that? I remember it was running good.
This suggestion might help in 2 areas, your clogged aerator and low water force when rinsing dishes. I bought a new faucet spray head from Amazon and it has the usual aeration stream and the shower stream on one push button. But then it has a second button that makes a more forceful flat stream like you might used to rinse plates and that stream is much more forceful. It screwed directly onto the spray hose with no adapter, easy peasy. Not exactly sure how they did it because it doesn’t appear that it has a reduced water flow, but boy does it work super well!
Here’s the Amazon link:
https://a.co/d/f4XxeFc
Can rave enough about this spray head!
