Kitchen Slide Out Drain Hose Problems..Again
Several years ago when I bought my Wildwood t25KS new, it developed a water leak under the kitchen slideout.. The problem was easily identified as the 1 1/2" flex drain hose that connected the sink to the main gray water drain line was punctured due to excessive rubbing on frame when slide was cycled in / out.. The dealer I bought it from supposidly corrected the problem (warranty) as it was a design flaw. They removed all sharp edges that the hose rubbed on and replaced the hose with a smaller size 1 1/4" hose.. This worked for several years and then the hose wore thru again.. This time I covered the exposed frame area where the hose rubbed with carpet.. rubbing only occurs at innermost 1/4 travel of slide (stowed position) but still damages the hose. Shortening the hose is not an option as all of it is needed when the slide is out.. Now the hose has worn thru again and it leaks when draining the sink (no pressure on line)! Looking for any and all suggestions that might help or correct this design flaw other than replacing hose every year or so.. Hopefully photos will show my problem..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
