Sorry to hear about your trouble. First thing you should do when leaving the camper for any length of time is turn off the water at the hookup. If you don't have a pressure regulator at the hookup and the water pressure goes up for any reason it can cause a line inside to rupture or blow out the plastic valve at your toilet. Some campgrounds have the water pressure set high (80 to 100 psi) to compensate for when they have a lot of campers.
Water regulated to 45 psi should be enough and will not be high enough to cause a rupture. I have heard the lines in campers are good for 50 psi.
Richard & Jill
