Leak, or what?
Where is the water coming from? 2019 Freedom Express 246RKS. Recently removed stabilizers to detail them (nasty looking and some rust) I was very surprised to see rust along the perimeter of the frame where underbelly attaches. Heavy rust in some places. Had to use my air de-scaler to remove.
To keep it brief. The porous edge of underbelly (like a yard sign) was weeping water. A 1/4" hole in the center of a sag in the underbelly, in the front, let out about a gallon of water. Removed underbelly and found more rust where underbelly was attached and could not be seen. There was evidence that water had pooled in the forward section of the underbelly. (rust rings). The most forward holding tank is grey water. The hose clamp where the plumbing pipe attached to the tank was rusty (the screw portion, not the band) )(haven't replaced yet). So It appeared to be the source of the leak. Filled the gray tank 2/3 and no leak! Three days and not a drop. Now I've filled the black tank and still no leak! Attached city water to trailer, no leaks. Turned on and off, one by one, all water faucets. Observed and no leaks. (btw. I park my TT on the side of my house where i have a 30amp connection and a sewer cleanout. fyi) I'm letting it sit and keeping a eye out for water. Somehow water got in my underbelly. And it's been there for some time (off and on??) due to the amount of rust i saw. And it's only on the frame forward of the axles. Tried to get Coachmen (Forest River) to send me a plumbing diagram. That was a joke. Sorry this was so lengthy. But has anyone with this, or a similar rig experienced this issue? Thank you! John
