Old 03-05-2017, 07:44 PM   #1
Sagecoachdriver's Avatar
Leaking from WH Pressure Relief valve on 110v only
Atwood water heater is leaking from the pressure relief valve, but only when using the 110v for heating. Doesn't leak on gas mode. I tried opening and closing the PR valve but it still leaks. This is only tank water, not City water hooked up. Any ideas?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 3
Sagecoachdriver is offline   Reply With Quote
Old 03-05-2017, 07:48 PM   #2
SeaDog's Avatar
this is a WAG but could the thermostat for the electric side of things be set to high causing the slight over pressurization
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-05-2017, 07:49 PM   #3
Not abnormal. If you cant get it to seat, there are two possabilities. Defective 120 side thermostat or defective relief valve. Since it only seems to happen in the 120 side, replace the temp sensor.
donniedu is offline   Reply With Quote
Old 03-05-2017, 08:52 PM   #4
BTW, I made sure I had an air pocket in the tank. I am not sure if there is an adjustment on the 110v side of the Atwood water heater. I know it heats way up there to maybe 150 degrees.
Old 03-06-2017, 04:02 PM   #5
Owners manual has a section devoted to this. It's toward the back of the Atwood manual.
hillsdaletc is offline   Reply With Quote
110v, leak, pressure, valve
