There's not actually a gasket. It uses a cartridge system with rubber cups and o-rings. Your best bet is to just replace it with a good residential model.
If you're handy and you want to try to repair it there should be a set screw behind the handle that allows you to pull it off and then you can remove the cartridge. It'll probably be a hex head screw, but it could be a flat head.
Gotta go campin!
