Old 09-22-2020, 12:26 PM   #1
leaking toilet at base
My toilet is leaking at the base. How do I repair the leak? I have the seal.
Letarue
letarue is offline   Reply With Quote
Old 09-22-2020, 12:35 PM   #2
The seal that goes at the bottom of the toilet?
If you don't know how to remove the toilet, there should be an online manual at the toilet manufacturer's website that will tell you how to remove it and replace the seal. Those seals aren't very durable.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 09-22-2020, 12:53 PM   #3
Head Rambler
If it's the flange seal they're all pretty much the same as far as replacing them.
1. Remove the water line.
2. Remove the two hold down bolts.
3. Lift the toilet off the flange.
4. Remove and replace the gasket.
5. Reinstall the toilet in reverse order 3 to 1.
Gotta go campin!
leak
